A few questions
Old 16 Jul 2013, 06:41 pm
Default A few questions
Hey everyone,
Just joined the forums and wanted to ask a few questions right off as i'm currently in my garage trying to figure out what is wrong with it.
So i've changed the cars ecu a couple of weeks back(my mechanic did), so after a few hours of driving my cluster starts lighting up all needles violently moving, stopped the car everything turned to normal and check engine light up, checked the error - hr 3308 no idea what it is as if the code does not exist, went back to the mechanic (the guy said that the car is too much hassle and he won't work on it again) he claims that it's some sort of wiring issue, yesterday the engine fan stopped working, and well... the car overheated... checked on the relays they seem to be ok.
Are there any places in the pt cruise that are particularly vulnerable in terms of wiring or any common wiring problems?
thanks a bunch for your replies
Old 16 Jul 2013, 06:49 pm
randyincctx's Avatar
Question Re: A few questions
First thing: Welcome to the forum!....That said;you'll need to tell everybody some more info about your PT....Depending on what year,how many miles,what engine,etc....These little bits of info really help in answering random questions.
Aka:~KILLER~
Old 16 Jul 2013, 06:54 pm
Default Re: A few questions
Welcome to the forum.
I think you did the fault code retrieval wrong and what you got was a system code. There is no hr 3308. Try this.....
How to retrieve fault codes.
The radiator fan is a known problem but not usually both speeds. You have two speeds if you have a 2001-2005. Usually the low speed stops working because of burnt out brushes in the fan motor. Can yo tell if any speed is working?
Don't know why all your needles were jumping around but if there was something wrong with the ECU/PCM you wouldn't have been able to start the car.
To rest the computer and get rid of old fault codes, take off the negative battery cable for about 5 minutes. Step on the brake pedal while the cable is off, put it all back together and the computer will reset to all normal settings.
Old 16 Jul 2013, 07:05 pm
thanks for the warm welcome,
Mine is an 06 non-turbo with 75k miles on it.
The fan is not working at all.
The thing is that i did the fault code check right, the weird part is that the scanner doesn't pick up any codes but the check engine light is still on, I'm still checking on the wiring around engine fuse box, so I guess by the time I'm done everything will reset completely
Old 16 Jul 2013, 07:18 pm
The bad part is that 2006 was the big change in electronics in the PT Cruiser. Chrysler changed to a CAN-BUSS system where everything is connected to another in one way or another and there have been problems with the TIPM (Totally Integrated Power Module) which is another name for the fuse box located in the engine compartment which is something I'm completely unfamiliar with...so I'll butt out. Sorry.
Old 16 Jul 2013, 07:21 pm
I was surprised by the fuse box a few hours ago, i've found a few damaged cables that i plan to weld in a moment, see picture attached, though this fan problem is still bothering me...
Old 16 Jul 2013, 07:32 pm
That's a PT Cruiser ????
Old 16 Jul 2013, 07:47 pm
Yup...
No air filter no battery and no fuse box at the moment still working on the messy wires (guess I'm not the first one lol)
damn dirty engine compartment
Old 16 Jul 2013, 08:15 pm
Clean on the outside.
Old 16 Jul 2013, 08:19 pm
Im in Canada no point in washing the engine as it'll be dirty in a day
2 more questions..noobe questions.. BarbieCar General Turbo Discussions 9 20 May 2012 07:32 pm
2 questions.... Stace22 Tech & Performance Forum 12 11 Jan 2011 10:44 am
New guy here with some questions heifetz17 Sound and Security Forum 4 14 Dec 2010 09:49 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
Questions on 3" Cat's PTGT_Boy General Turbo Discussions 4 12 May 2004 08:09 pm
