Over heating issues
Like Tree4Likes
Old 17 Jul 2013, 02:11 pm
Exclamation Over heating issues
I bought the car from an older gentleman and he had replaced the thermostat and water pump. I had a family friend mechanic look at it and he said there was air bubbles in the coolant lines... and i need to flush it out. I had another friend look at it and he said the thermostat might be in upside down.
When i go up hills it starts heating up past the halfway mark, or in its above 70 Degrees and I take the freeway. If i have the heater on it will go back down to halfway in about 5 minutes. When I go down a hill though it goes down past the half mark even if it was just really hot.
Old 17 Jul 2013, 03:55 pm
randyincctx's Avatar
Exclamation Re: Over heating issues
Start simple.....The coolant system MUST be properly 'Burped' to get ALL air out,otherwise it can make a PT run hot/overheat...Bleeding air from cooling system
Aka:~KILLER~
Old 17 Jul 2013, 04:19 pm
Instead of getting opinions why not just get it fixed!
QUOTE=jesse_smiley;484566]I bought the car from an older gentleman and he had replaced the thermostat and water pump. I had a family friend mechanic look at it and he said there was air bubbles in the coolant lines... and i need to flush it out. I had another friend look at it and he said the thermostat might be in upside down.
When i go up hills it starts heating up past the halfway mark, or in its above 70 Degrees and I take the freeway. If i have the heater on it will go back down to halfway in about 5 minutes. When I go down a hill though it goes down past the half mark even if it was just really hot.[/QUOTE]
Badglas likes this.
Old 18 Jul 2013, 05:40 am
Send a message via AIM to verongome Send a message via Skype™ to verongome
Default Re: Over heating issues
[/QUOTE]
Hahaha true, just take it to the nearest garage and ask them to have a look and voila its fixed.
BacklinksVault
Old 18 Jul 2013, 09:11 am
Yeah it doesn't sound like his "friends" are helping
Hahaha true, just take it to the nearest garage and ask them to have a look and voila its fixed.[/QUOTE]
Old 18 Jul 2013, 09:43 am
What I would like to get is the crystal ball some of you use? I mean making suggestion to solving an issue without knowing what year and model the PT is and a few other important evaluation questions ? Wow you guys are my hero!
Old 18 Jul 2013, 10:43 am
I assume since its having so many issues its a gen2
randyincctx likes this.
Old 18 Jul 2013, 10:52 am
no guess as to your problem, but you can easily see if your thermostat is upside down. suck a little coolant out with a turkey baster and look in the hole.
you should see the top of this, not the bottom:
like this:
is your coolant full all the way to the cap?
after you drive it and it cools down, is your coolant still full all the way to the cap?
i have NEVER bothered to do this to my car.. maybe it SHOULD be but by no means MUST it be. i just top it off again after it cools. same thing.
Old 18 Jul 2013, 01:46 pm
Wink Re: Over heating issues
I don't use a crystal ball,that would just be silly....I have a 'Magic 8-Ball' for that!!!!
Question: "Why is my PT Cruiser overheating?"
Aka:~KILLER~
Old 18 Jul 2013, 01:49 pm
Question Re: Over heating issues
Won't he do more than look at it???....Like fix it for you?
Aka:~KILLER~
Tags
overheating, thermostats, upside down
PT Over Heating Rekoj Tech & Performance Forum 16 22 Jul 2013 03:13 am
Over Heating issues on a 2000 Limited Edition Automatic transmission Draven76 Europe PT Forum 4 07 Apr 2013 10:52 am
over heating priest Tech & Performance Forum 1 27 Jul 2010 06:10 pm
02 Over heating Smash General PT Cruiser Discussions 1 13 May 2010 02:24 pm
O gee! !!!!! my PT is over heating!!!!!!!!!!!!!!!! Ctown General PT Cruiser Discussions 8 03 Jun 2006 07:07 pm
