Broken Air Box Mounting Post(s)-FIX!
Like Tree2Likes
  • 1 Post By randyincctx
  • 1 Post By Busted_PT
Old 18 Jul 2013, 08:45 pm
randyincctx's Avatar
Lightbulb Broken Air Box Mounting Post(s)-FIX!
AIR BOX POST FIX
NOTE: MUST have broken 'nipple(s)' from stock air box for this to work!!!!!
Supplies needed
1 pkg-Hillman Hex Cap Screws Class 8.8 M6-1.00 x 25 (upc#0-08236-71048-9)
1 pkg-Crown Bolt 1/4 in. Stainless Steel Flat Washers (upc#0-30699-32491-0)
1 pkg- JB Weld
1-Size 7/32 Dia. Drill Bit
10mm socket
Clean air box & broken post(s) with soap & water,and dry well;Next,using the 7/32 drill bit carefully ream out the posthole in the air box & the broken post(s) stopping to test fit the bolt periodically until it fits snug(NOT too loose/NOT too tight!)....You want it to be able to hold the post in place;When you have the hole(s) just right,clean all the surfaces to be 'glued' with rubbing alcohol.....Next mix up the JB Weld and apply to broken edges of post & air box,and to the threads of the bolt(s);Then while holding the broken post(s) in place tighten it with a 10mm socket till snug(don't forget the washer!)and wipe away any excess that squeezes out.......Then let it set for 24 hours to allow the JB Weld to harden;After that it can be re-install in the car......I not only did this FIX to repair my one broken post,but went ahead and did the un-broken one also.(so it won't ever break!)...Hope this helps other with this problem.
07-13-13_2203.jpg<----This was the broken post!(You can barely see where the crack was.)
07-13-13_2205.jpg<-----View from inside showing bolt & washer.
garkeller likes this.
Aka:~KILLER~
Old 18 Jul 2013, 09:50 pm
Default Re: Broken Air Box Mounting Post(s)-FIX!
That's good. I've done this myself.
randyincctx likes this.
Old 18 Jul 2013, 09:57 pm
Thumbs up Re: Broken Air Box Mounting Post(s)-FIX!
I figured I wasn't the first!....Alot better than buying a new,or even a used one......Parts used probably cost less than $3(and I have leftovers)......
Aka:~KILLER~
Old 19 Jul 2013, 07:40 am
I'm all about saving money, without compromising the job.
Broken timing belt/broken valves DreamCar Tech & Performance Forum 17 13 Mar 2012 01:35 pm
Ipad Mounting Cilos Interior Accessories Forum 3 03 May 2011 07:24 pm
