Blowing high-beam fuses
Like Tree2Likes
  • 2 Post By otfiddler
Old 19 Jul 2013, 01:10 pm
Default Blowing high-beam fuses
I've been driving without fuse #8 and fog lamps for a couple of years now, and I've just noticed that when I attempt to switch on high beams I blow fuse #16 --- might that be related to the suspect Multi-Function Switch?
Old 26 Aug 2013, 07:22 am
Default Re: Blowing high-beam fuses
OK, I've answered my own question --- I replaced the Multi-Function Switch, and I still blow fuse #16 ( but at least I have fog lights again).
My next question is, can high-beam bulbs cause fuse #16 to blow when a bulb dies?
I hate to buy new bulbs if it won't fix my problem, because I suspect I won't be able to return them.
Old 26 Aug 2013, 07:36 am
Just look at the bulbs and see if they are blown. If Filament is not broken, get to work finding the short. check the wiring behind the fuse block for charring. If no luck there start following the wires from the head lights back, looking for damage or rubbing on metal edges.
Old 13 Sep 2013, 12:53 pm
Closure:
After shedding some skin and blood working through the tiny opening in the wheel well to determine the condition of my high-beam bulb filaments, I noticed that the wire to my right-side lamp had in fact been pinched --- at some time in the past someone had apparently removed the front fascia, and during re-assembly, had trapped the wire between the car frame and the fascia.
I loosened two nuts enough to release the wire (fascia removal was not required), wrapped the mashed area with electrical tape and re-assembled everything.
I now once again have low beams, high beams AND fog lamps; life is good!
Old 13 Sep 2013, 01:42 pm
Talking Re: Blowing high-beam fuses
It is truly amazing the amount of money that can be saved on repair and maintenance of our vehicles just by logging on here and grazing every few days.
That witch hunt looking for a pinched or shorted wire would have cost at least a half hour dealer diagnostic time. Close to $40 at my local dealer.
Old 29 Apr 2014, 07:23 pm
Just discovered that I am having the same problem. I just had my rides pt convertible repainted and some body work done, and found that it is the fuse just a few minutes ago. When you say it was pinched by the front fascia, do you mean the front bumper? I looked some, but didn't really have the daylight left to do much. Any help would be appreciated.
Radiator Fan Fuses Keep Blowing! kmbkk Tech & Performance Forum 5 17 Jul 2013 10:33 pm
High beam fuse keeps blowing 92awd4g63 General PT Cruiser Discussions 5 23 Nov 2010 03:18 pm
Blowing Fuses DavidEtling General PT Cruiser Discussions 3 11 May 2010 05:07 pm
Fog Light fuses repeatedly blowing deathcabdan Exterior Accessories Forum 3 08 Mar 2010 05:31 pm
Blowing Fuses DragAsp Tech & Performance Forum 5 21 Apr 2008 11:33 pm
