door locks
Old 20 Jul 2013, 12:59 am
Default door locks
I have a 06 cruiser and the back doors will not close. one of the doors will not close or latch. the other back door will not open from the inside or outside. i have to duck tape the door closed. any ideas why the back doors wont operate? sometimes i can get it to latch, but rarely.
thanks
Old 20 Jul 2013, 05:43 am
Tobymelodeon's Avatar
Default Re: door locks
I had a similar problem on one of my other rides... Found that taking the catch assembly off and cleaning it up and relubricating it all did the trick! Check for any bent or broken parts too. Easy replacement if you need to go down that route. With the oor not actually closing, it indicates that the problem is with the catch rather than the central locking, which is good news as the central looking system can be a bit of a minefield! Good luck!
2002 PT Cruiser CRD in Bright Silver.
Current Upgrades
Chrome door handle cups, chrome pillar covers, tinted windows, custom vinyl flame decals, alloy wheel decals, Enrgy bush kit, Engine cover MOD, LED Side Repeaters
17" Ace Manta Alloys, Red Brake callipers, Front grille MOD
Project list (wish list)
Rear bumper mod to DIY roll pan
Custom paint job (probably purple front end with flames running into the silver)
Air intake upgrade...
Old 20 Jul 2013, 03:03 pm
fy9-03pt's Avatar
If it is happening to all the doors then it sounds like the relay or control is not setting . if it stuck in the release position with the current still open then it sounds like an electrical short .could be a common wire loose or off .Pull the door panel and get lock switch out and check the wiring or may need to be replaced. take to local auto shop ( autozone,advance,O'reilys see if they can check it out with a meter might be bad. Could also be a bare wire rubbing somewhere.
Hope this helps, Bobby
Robert
Old 20 Jul 2013, 03:14 pm
fy9-03pt's Avatar
A--------------______________%%%%%%%%%658585868954
Robert
Old 20 Jul 2013, 08:48 pm
randyincctx's Avatar
Cool Re: door locks
First culprit I would suspect would be corrosion,which I would fix with PB Blaster or WD-40;Then next thing I would check would be a faulty latch mechanism,which I would remove & examine closely.....And replace if I couldn't get it to function properly.
Aka:~KILLER~
Door Locks HerDiamond2 General PT Cruiser Discussions 0 08 Apr 2012 08:38 pm
PLEASE HELP ME! door locks yteka99 General PT Cruiser Discussions 5 03 Nov 2009 01:21 am
door locks careyk General PT Cruiser Discussions 4 24 Sep 2008 10:58 am
door locks funluvinkruzr PT Cruiser Convertible Forum 0 28 Feb 2006 12:54 am
Door locks umaxman Tech & Performance Forum 7 14 Nov 2004 12:09 pm
