"Pop" when shifting into reverse
Old 23 Jul 2013, 06:51 am
Default "Pop" when shifting into reverse
Within the past week, I have started to hear a "pop" sound when shifting the automatic tranny into reverse before backing out in the morning. It sounds like it is coming from lower center of the engine compartment, but hard to tell for sure. Other than that, transmission behavior is completely normal. Fluid levels are good. Any ideas?
2005 N/A, Cool Vanilla
Adds
PT Wheel Centers, PT Valve Stem Caps
Mopar Chrome Exhaust Tip
Mopar Molded Rear Splash Guards
Mopar Rear Step Pad
K&N Filter
Pioneer Speakers/Receiver w/BlueTooth & HD Radio
Mopar Powered Sub
Old 23 Jul 2013, 09:27 am
Default Re: "Pop" when shifting into reverse
Check this Chrysler service notice
"BULLETIN NUMBER: 03-006-04
DATE: September 15, 2004
SUBJECT:
Front Hub/Half Shaft Click/Pop Sound
OVERVIEW:
This bulletin involves installing a rubber gasket to the face of the half shaft that mounts to the hub bearing.
MODELS:
2000 - 2005 (PL) Neon
2001 - 2004 (PT) Chrysler PT Cruiser
NOTE: This bulletin applies to PT vehicles built prior to February 18, 2004,
SYMPTOM/CONDITION:
Vehicle may exhibit a popping/clicking/snapping/ticking sound from the front hub/half shaft area during acceleration after Drive to Reverse or Reverse to Drive shifts. The sound may also be present while turning and accelerating from a stop."
Old 23 Jul 2013, 11:02 am
Thanks. Sounds similar, but not exactly the same. Also, my PT was manufactured after the dates listed in the TSB. I am hoping this is not indicative of some major failure that is pending.
Adds
Mopar Rear Step Pad
K&N Filter
Mopar Powered Sub
Old 23 Jul 2013, 12:57 pm
Sorry to hijack the thread, but this sounds exactly like my issue! Although, my is an 06. Is it possible this situation could happen to the newer style?
I just assumed that either my mounts have gone bad or the drive axle' cv joint have gone bad.
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
2006 Inferno Red Limited with the Turbo
Old 24 Jul 2013, 06:58 am
santandharma: I just re-read my reply....I didn't mean to sound dismissive of that TSB information you provided. It just isn't an exact fit for my issue. I do wonder if that rubber gasket was something that was added to later models at the time of manufacture - if so, then it could be that mine has worn out.
The sound I'm hearing always happens after a cold start, when I shift into reverse for the first time when the engine is still cold. I've run through forward and reverse multiple times after the car is warm and cannot get the sound to repeat. I'm hoping it is more of a nuisance than an actual problem.
HanaTurbo, no worries about chiming in. Others here have more experience than me, but my thoughts on your suggestions: when my mounts were bad, I heard a "thunk" almost every time I goosed the throttle. It was pretty easy to make the sound repeat. It it was a CV joint, I'm pretty sure the noise would be constant or at least a lot more frequent than what I'm hearing.
Adds
Mopar Rear Step Pad
K&N Filter
Mopar Powered Sub
Old 24 Jul 2013, 10:20 am
05vanilla,
Thanks for your input, you are correct. It is easy to replicate and happens often. Looks like I have to get some new axles.
Old 03 Oct 2013, 07:36 am
Forgot to update the cause/resolution on this: stupidity! When I replaced the engine torque struts, I incorrectly torqued the lower strut. It came loose, resulting in that "pop" sound. Oops.
Adds
Mopar Rear Step Pad
K&N Filter
Mopar Powered Sub
Old 03 Oct 2013, 07:45 am
That could happen to anyone. Great that you followed up. Somebody else will do it to.
"G" fell off my "Touring"... rockandroller The Detail Shop 19 03 Feb 2015 07:05 pm
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 04 Mar 2013 12:49 am
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Part number for "PT" door emblems on 2008 Dream Cruiser 5 gpr75 General PT Cruiser Discussions 6 16 Jul 2010 12:15 pm
