Engine Revs up and down by itself
Old 23 Jul 2013, 11:14 am
Default Engine Revs up and down by itself
On engine start, the engine revs from about 800 rpm to about 1500 rpm. After it warms a bit it does settle down but still moves up and down. Any ideas.
BTW, this is the wife's car. I can't stand it as it is an engineering failure in my view.
Old 23 Jul 2013, 11:54 am
Default Re: Engine Revs up and down by itself
sounds like a vacuum leak to me.
2016 Kia Soul Plus Black
Old 23 Jul 2013, 12:06 pm
Me too. Check the lines coming from the brake booster. That's where I found the vacuum leak on mine.
Old 23 Jul 2013, 12:51 pm
Oh the old it's the wife's car bit! Yeah I was gonna go with that but now I find that I like the goofy little PT!
But sounds like a vacuum leak to me also. When I did the spark plugs (an adventure in itself!) A hose on the back of the manifold fell off and the car was doing what you described. I also found the PCV hose was cracked at both ends not causing a problem and will be replaced. There is an o ring that is held in place with a bracket that holds the throttle body to the manifold on the back right hand side of the manifold. I had to undo that bolt and bracket and it held a metal tube that goes into the manifold that has an O ring in and the O ring was broken but I stuffed it back in till I get it replaced.
Basically if you do the spark plugs which it might need anyway? Youd find these hoses as you go along.
The old school way to find a vacuum leak is just get a can of throttle body cleaner (02 safe). And spray the crap out of everything that looks like a vacuum line! If the rpm goes up...you've found your leak!
Some of the younger crowd voiced concern about this method but I've done it for years and haven't blown anything up yet! So consider yourself warned!
Tags
engine rpm
Auto Trans problem? Engine revs, no go tlturbo Tech & Performance Forum 6 25 Jul 2013 05:06 am
Weird noise when engine revs luckymagruder Tech & Performance Forum 2 20 Oct 2012 02:19 pm
Engine Revs and then dies at start Chas777 Tech & Performance Forum 3 12 Jun 2011 06:53 pm
Engine revs up automatically ProDigit General PT Cruiser Discussions 2 07 Feb 2011 07:09 pm
Engine revs while idling when air or heat is on mags593 Tech & Performance Forum 2 14 Apr 2010 09:34 pm
