02 pt starts to stall with ac on?
Old 23 Jul 2013, 11:43 am
Default 02 pt starts to stall with ac on?
02 pt no turbo with only 80,000 miles.. when you turn the ac on and start to drive it wants to stall be keeps going.. When you stop at a light same thing but never dies.. When turning the stearing wheel all the way same thing... Any ideas theres no trouble codes showing
Old 23 Jul 2013, 11:52 am
Default Re: 02 pt starts to stall with ac on?
when you turn the ac on, you should be able to hear the radiator fan kick in. if not, there's your problem. common problem with pt fans.
2016 Kia Soul Plus Black
Old 23 Jul 2013, 12:00 pm
the fan works just fine...
Old 30 Jul 2013, 04:05 pm
It also does it with the ac off any ideas? Cleaned the IAC yesterday nothing helped
Old 30 Jul 2013, 04:33 pm
Went looking around at older threads and the Internet. Three things came up. The Power Steering Pressure switch sends a signal to the PCM to raise the idle when the power steering is used to compensate for the small loss of power. If the IAC is cleaned and working properly, the TPS (Throttle Position Sensor) (also located on the TB) could be at fault as well as built up carbon inside the throttle body affecting the butterfly control.
The Clockspring inside the steering wheel came up but it was also related to the radio which had problems and it all related to the wires than ran down the steering column, but you didn't mention any other problems.
A/C will cause engine to stall Johnlittle01 General Turbo Discussions 11 15 Jul 2012 01:03 pm
Low idle stall issues. deb56 General PT Cruiser Discussions 13 15 Jan 2012 02:20 pm
Surge/stall Badger General PT Cruiser Discussions 0 30 Mar 2011 03:39 pm
Can You Describe A Stall? NewPTCruiserInPA Tech & Performance Forum 13 15 Sep 2008 02:28 pm
Engine Stall Johns Steel Blue Tech & Performance Forum 16 19 Feb 2007 03:38 pm
