tune up stuff..
Like Tree3Likes
Old 23 Jul 2013, 11:23 pm
Default tune up stuff..
i would like to do a tune up, my first one
so i have seen many treads about the special spark plugs for the turbo version, mine is 06 2.4L light turbo with 67k.
please if someone can write a list of all what i need, and which brands are good for each part (oil, filter, cables...) coz the deal with the mechanic is to bring all the parts, and he will do the job..
ps : went to one of those known places and they ask $350 for a tuneup!! is this a regular price??
by the way am programmer and i would like to build an iPhone/android app dedicated to pt cruiser.. if someone have some ideas..
Thanks in advance
Old 24 Jul 2013, 03:38 am
Default Re: tune up stuff..
Nowadays there is really nothing to "tune-up" (ie--points, condenser, rotor, cap, carb adjust,etc.) so $350 sounds like an outrageous price...don't know what they plan on doing in order to charge that amount.
About the only thing left to do nowadays is the plugs and perhaps clean out the throttle body and replace the air filter. At the same time you might want to do an oil change and lube (only 2 fittings on my PT...again, not like the old days). Trans fluid and filter change would also be a good idea.
Old 24 Jul 2013, 08:58 am
Plug wires! Still that is a stupid price.
Old 26 Jul 2013, 06:02 pm
I wana order all the parts online, but am still confused..
Spak plug : gap @0.50, 0.52, or 0.44???
Spark plug : titanium, ngk, bosh.. which brand/model is good?
Oil : mobile or other brand??
Oil : w40, w30, w50...
Oil filter : what size/ model??
Spark plug cables : which size or model # do i need..
That's all for now.. Will update if there is any other part needed.
Thanks a lot.
Old 27 Jul 2013, 03:11 am
gram; there is a sticker in the engine area and there is an owners manual which gives you that info. Check oil fill cap too. Factory spark plug wires worked well for me.
Carl48 likes this.
Old 27 Jul 2013, 04:05 am
Everybody will have a personal opinion as to which oil and filter and plug is best. Check the oil filler cap or owner manual for proper viscosity and buy whichever brand you prefer that has the API seal on the bottle for gasoline engine service. The owner manual will tell the capacity...my na PT takes 5 qts. IMHO the WIX or NAPA filters are the best. The parts counter guy can tell you the filter part number for your application. Don't forget the air filter while you are at it.
Old 18 Aug 2013, 10:44 pm
rockandroller's Avatar
Thanks in advance
about your app... if its a music player - please make sure it can play FLAC files
2004 'Turbo Lite'
Old 18 Aug 2013, 10:47 pm
... and back on the subject of "spark plug gap" - my (2004) engine compartment sticker says .050 - but revised spec means that's supposed to be smaller, right? (Also have the Turbo Lite...)
All the PT plugs on RockAuto seem to be spec'd for .050 gap
2004 'Turbo Lite'
Old 19 Aug 2013, 01:06 am
Rock; on a 2003 sebring non turbo, the factory changed the plug gap to .040. Try TSB # 08-008-04.
Old 28 Aug 2013, 11:13 am
Synthetic oil is better and worth the extra cost - Mobil 1 5w30 is what you want.
Check with Advance Auto - they often have a deal on 5 qts of Mobil 1 oil and a Mobil1 filter.
Get Crane Firewire plug wires, they have low resistance and will last much longer than the stock wires.
For plugs, the stock Champions aren't bad, get iridiums if you want longer life.
There was a TSb for smaller plug gap, and gap gets wider with age - I'd gap at 0.040.
mole likes this.
Tune up whiteclaw General PT Cruiser Discussions 12 10 Aug 2012 12:00 pm
tune up paddywagon General Turbo Discussions 3 21 Mar 2012 06:20 pm
Tune-up ? discovering06 Tech & Performance Forum 6 11 May 2008 03:56 pm
TUNE-UP HELP? 1lowufo Tech & Performance Forum 2 15 Aug 2004 10:15 am
