Engine rev when put in park
Old 25 Jul 2013, 07:52 pm
Default Engine rev when put in park
Hi everyone. For the past few months, my pt has been doing a rev when I shift from drive to park (it does it when the shifter enters the park position--shifting from drive to neutral causes no rev). It started as an infrequent event, but now happens about 90% of the time. When you shift into park, it revs up to about 1500 and then drops right back down to normal park idle. It's not really bugging me, I'm just curious as to what might be going on. This week I pulled the IAC valve and cleaned it, but that didn't really do too much.
As always, I appreciate everyone's willingness to help!
Old 25 Jul 2013, 08:27 pm
Default Re: Engine rev when put in park
Might be a problem with the TPS (Throttle Position Sensor), also located on the throttle body.
Old 25 Jul 2013, 09:19 pm
Thanks for the feedback! I should also mention that the idle sometimes fluctuates slowly (normal for the count of 2 or 3, slight decrease in rpm, back to normal for a count of 2 or 3,repeat) when I idle with the brakes applied in drive. This doesn't happen as much and tends to be when the a/c is on ...but the fluctuation doesn't coincide with the compressor coming on or off.
Also, my acceleration is smooth and I have never had any issues with hesitation or anything like that.
Oh, in case it is helpful, I have an '01 non-turbo w/ about 185K.
Thanks again!
Old 26 Jul 2013, 06:27 am
Jd; check for vacuum leaks too.
Old 26 Jul 2013, 06:52 am
^^^ Agree. A large vacuum leak, like a hose falling off, will cause the idle to radically go up and down. Had that myself with the hose from the brake booster. A small tear or lose fitting vacuum line (which is hard to find) could cause the up and down movement as you mentioned.
Shaking in Park & Check Engine Light sarahajoseph09 Tech & Performance Forum 3 31 Mar 2012 12:38 pm
engine will not rev above 1500 in park bbccdc Tech & Performance Forum 5 23 Mar 2012 10:47 am
Going to Raceway Park.Who wants to come ? XtrmDC2 Northeast PT Forum 4 29 Sep 2011 07:12 pm
PT - a Day in the Park (and other distractions) Chromenut PT Cruiser Convertible Forum 5 15 Jul 2011 06:24 pm
Ever been to a Zoological Park? Wally Southeast PT Forum 0 07 Feb 2004 04:45 pm
