weird Idle issue.
Old 27 Jul 2013, 11:43 pm
Default weird Idle issue.
When driving my car the temp gauge sits fine pointing directly to the middle. However when i sit and idle, lets say picking up my daughter from her friends house, the car temp gauge will go up about 1 notch. Doesnt go into the red, but not sure if it would if i sat there for a long period of time. Once i start driving again it cools right back down to normal operating temp. I dont blow white smoke out of my exhaust.. What could be the issue? Any ideas on what to check?
Possible bad low/high rad fan? how could i test this?
Old 28 Jul 2013, 07:26 am
Default Re: weird Idle issue.
Do you here the fan come on? Dose it do it when the ac is on? What year and such is your pt? You are right to state there.
Old 29 Jul 2013, 01:26 am
I will have to check about the fan coming on. I dont have ac, my compressor just cycles on and off. I have a 2001 Limited Is there ways i can jump the fans to see if they kick on?
Old 29 Jul 2013, 04:16 am
Garya1682's Avatar
Send a message via Skype™ to Garya1682
ive just spent almost 3 months trying to find the cause of my overheating issue it got to the point where I had steam coming out of the engine and I was in the red zone and mine started out doing excactly what you've just described, but I wouldn't worry just yet as it may not be the same issue.
if I sat idle for longer than say 30 minutes my temp gauge would start to climb and within minutes of it starting I would be in the red and the cause of that was a faulty fan motor and a broken wiring loom that runs down the front of the vehicle I would advise you to check the wires for any breaks/splits as one of those cables controls the fan from the ecu. also check your highspeed and lowspeed modules for faulty ones I replaced both but ultimately it was the wires + fan motor that caused my issue.
2002 cruiser
2.0L PETROL AUTO
80k miles
Old 29 Jul 2013, 10:14 am
well the fan is kicking on, Once the temp gets to the middle line. Is that low or high speed? My ac compressor cycles but when it does the fan was kicking on and off.
Old 29 Jul 2013, 10:47 am
Unplug the fan and jump the motor with a wire. Middle is ground . The outers are high and low If the fan runs on both sides it's ok.
Old 29 Jul 2013, 10:55 am
is the fan harness located under the car?
Old 29 Jul 2013, 12:51 pm
Ignore the previous post. I found it, jumped it and both speeds, high and low kick on. What to check for next?
Old 29 Jul 2013, 01:35 pm
have you checked the level of coolant in the radiator as well as the overflow tank? please do this when it has cooled down.
2016 Kia Soul Plus Black
Old 29 Jul 2013, 02:12 pm
sure will, just picked up my daughter so i will let it cool down a bit. The overflow tank is very dirty, i think i am gonna replace it with a new one from rock auto. Hard to see inside it.
very weird rad fan issue barthek Tech & Performance Forum 18 16 Dec 2013 04:11 am
Weird idle/ac issue. Ced_56 Tech & Performance Forum 4 08 Jun 2013 08:18 pm
weird issue Johns03PT General PT Cruiser Discussions 5 14 Dec 2012 08:15 pm
weird a/c issue bogie2929 Tech & Performance Forum 2 05 Aug 2012 09:54 am
Weird issue Opiate General PT Cruiser Discussions 4 09 Aug 2008 10:05 pm
