2005 Cruise: change fuel tank
Old 28 Jul 2013, 03:07 pm
Default 2005 Cruise: change fuel tank
I have never changed a fuel tank. Anyone have a service manual they could share info or point me in the right direction?
Old 28 Jul 2013, 04:35 pm
Default Re: 2005 Cruise: change fuel tank
here: http://www.filedropper.com/untitled-1
for what it's worth, the tank on mine came out really easily. the fuel line comes apart pretty effortlessly with the quick disconnect clips. getting the fill hose and vent line off the right rear is what i started with, then the electrical connector and fuel line(or lines? i dont remember if there was more than 1, either way, should be easy).
Old 29 Jul 2013, 02:01 pm
Make sure the tank is as empty as possible. You'll be suprised how heavy 2 or 3 gals of gas is when you're laying on your back Do not press on the center of the tank on the bottom. There's a round shape you can see. This is where the float arm is located. You don't want to bend or break this.
Some basics:
You're woking around GAS. Take precautions as needed
~ get some rags to soak up any drips or spills
~wear eye protection
~Remove neg battery cable.
~Rear of car on ramps.
~open fuel filler cap to release tank pressure.
~remove filler & vent tube from pass side of the tank via worm clamp.
~I made an 'H' brace with 2x4 so not to press on center of tank where fuel float is located and lowerered the tank with a floor jack after removing the two tank straps.
~lower it as far as you need to remove the power wire and fuel line.
~You'll need a fuel line tool or small needle nose pliers to remove the fuel hard line from the fuel canister cap on top of the tank.
Good Luck
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 07 Aug 2013, 02:16 pm
I am doing the same thing. Any idea how long the replacement takes from start to finish?
Old 07 Aug 2013, 04:07 pm
I took about 6 hours my time.
Old 07 Aug 2013, 06:44 pm
2006 once the wheels were off about 30-45 minutes with 1 gallon left in the tank to remove it. The same maybe 15 minutes extra for installation?
After removing it
Cleaning it up
Old 11 Aug 2013, 06:48 pm
Got the tank off no problem. Went to put the new one on and noticed it had fallen over. This part broke. Any idea what it is?
05 pt fuel tank capacity 05ptvert PT Cruiser Convertible Forum 12 26 Jul 2013 07:02 am
Fuel tank straps DenisMcG Tech & Performance Forum 2 21 Nov 2012 06:52 pm
Fuel economy change with tire size change? Calab Tech & Performance Forum 7 11 Aug 2011 06:24 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel Tank Doors ?? Will an 03 fit my 06....?? outfit Exterior Accessories Forum 4 03 Oct 2008 04:48 pm
