Cranks but want start
Old 03 Aug 2013, 01:01 pm
Default Cranks but want start
i have a 2009 pt cruiser that will crank over but will not start....has fire and getting fuel to the fuel rail...no codes and shows nothing on the scanner.......i can squirt a little starting fluid in it and it will fire up but dies after it burns it out...(used a little for test only)someone point me in the right direction...thanks...Aubrey...ps....help be greatly appreciated
Old 03 Aug 2013, 02:22 pm
randyincctx's Avatar
Default Re: Cranks but want start
How many miles on your cruiser?....What model & engine?(Base,GT,Turbo,Ltd.,Tour.?)
Aka:~KILLER~
Old 03 Aug 2013, 05:28 pm
Randys' asking for the mileage because anywhere around 100,000, then the timing belt could have broken although most of the time a code will show up.
When you say no codes, do you at least get: "done" at the odometer reading?
Old 03 Aug 2013, 09:26 pm
has around 80000 miles......it will run off of starting fluid.....so it prob not the belt...i hooked a snap on scanner on it and said no codes stored.....but the ck engine light wasnt on anyways
Old 03 Aug 2013, 09:31 pm
It sounds to me like a fuel problem because its starting with starting fluid. Start by turning the key to the on position and listen for the fuel pump to start. If you dont hear it, check ur fuel pump relay in the fuse box under ur hood. If that doesnt give you a clue of whats going on, check out this vid on youtube. Should help you with your diagnostic.
Old 03 Aug 2013, 10:02 pm
it has fire....and it has fuel pressure......the injectors i think are not opening....runs fine on starting fluid.....what opens the injectors...
Old 03 Aug 2013, 10:03 pm
the plugs are dry
Old 03 Aug 2013, 11:59 pm
Well if the spark plugs are dry than there is something clogging up the fuel system since fuel isnt getting to the cylinder. You may want to conduct a fuel pressure test.
Old 04 Aug 2013, 12:00 am
Lightbulb Re: Cranks but want start
If you have a multi-meter/ohm-meter,unplug and check each electrical connector on the fuel injectors,and measure the resistance....The injector resistance should be between 11.4 to 12.6 ohms.
Aka:~KILLER~
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
Cranks but wont start master91599 Tech & Performance Forum 17 19 Dec 2011 02:58 pm
Cranks but don't start after TB replacement jdpersico Tech & Performance Forum 10 27 Oct 2011 03:20 pm
2001 PT cranks but won't start PT2001 General PT Cruiser Discussions 8 23 Oct 2010 10:41 am
