Water Pump and timing belt
Like Tree3Likes
Old 06 Aug 2013, 09:18 am
Default Water Pump and timing belt
2005 PT Cruiser convertible with 2.4L standard output turbo with 91,000 miles
I just paid a mechanic to replace my timing belt, drive belt, pulley and tensioners and seals, engine mount, intake gaskets, water pump, transmission fluid and filter, cam and crank were replaced also.
basically about everything on front right of motor replaced.
before this service work, my normal operating temp was at 1/2 on temp gauge. after repair car is running between 2/3 and 3/4 on temp gauge. it is not in red, but I am concerned about the hire normal operating temp.
any advice would be appreciated!!!!
Old 06 Aug 2013, 09:21 am
Default Re: Water Pump and timing belt
Replacing the water pump means the mechanic took out and maybe replaced the coolant. My guess is that it wasn't properly bled of all the excess air. Have it done before it gets worse and keep an eye on the temp till you do.
Old 06 Aug 2013, 09:37 am
coolant was not replaced. could it still be excess air?
i am being very careful with temp and not driving car much at all. When I do I put top down and turn on heater. Temp stays OK with good air flow on highway, but goes up in traffic
Old 06 Aug 2013, 09:47 am
even if the coolant was not replaced, it runs thru the water pump. air could have gotten into the system when it was changed out. as crewzin stated, bleed the system first.
CREWZIN likes this.
2016 Kia Soul Plus Black
Old 06 Aug 2013, 10:39 am
PTJunkie's Avatar
Why would you replace all those parts and go through all that labor and expense, and not replace the coolant?
chromer don likes this.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 06 Aug 2013, 11:05 am
cruserdad1976's Avatar
you will losse some coolent when you take out the pump
Old 06 Aug 2013, 01:07 pm
Check yo see if the fan runs when you turn the AC on. If know fan then it could be unplugged.
Old 06 Aug 2013, 04:15 pm
radiator fan works fine on both its low speed and its high speed
Old 06 Aug 2013, 04:24 pm
could it be a thermostat issue?
Old 06 Aug 2013, 06:17 pm
If the fan comes on when it is supposed to then it had to be something like that or air as the others suggest.
Tags
hot
DIY Water Pump/Timing Belt tooter1 Tech & Performance Forum 16 06 Oct 2012 09:18 pm
Timing Belt/Water Pump sonocativo General PT Cruiser Discussions 6 31 Jul 2012 04:11 pm
Timing Belt/Water Pump Help MamaCruiser Tech & Performance Forum 5 20 Oct 2011 12:15 pm
Timing Belt/Water Pump mybubbles65 General PT Cruiser Discussions 3 04 Oct 2011 04:47 pm
water pump and timing belt bryanschacht Tech & Performance Forum 3 15 Apr 2011 05:32 pm
