Transmission issue!!
Old 12 Aug 2013, 11:28 pm
Default Transmission issue!!
first, we talk about 06 turbo auto transmission.
the transmission is very smooth when driving, the only problem is that there's loud thud sound and the car jerks like something is going to break when i shift to D or R, this thing happen only sometimes,
also when am about to stop at the red light when the transmission downgrade i feel the same thing.. this only happened 2 or 3 times,
anyone with the same problem? any fix to this?
thank you
Old 13 Aug 2013, 09:27 pm
compdr59's Avatar
Default Re: Transmission issue!!
Sounds like motor mounts.
Original Owner 135k
Old 14 Aug 2013, 07:22 am
[QUOTE=compdr59;488125]Sounds like motor mounts.[/QUOTE]
Definitely what he said. ^^^^^
Old 14 Aug 2013, 08:49 am
Description on a forum can be deceiving? To me i would ask when you had the transmission serviced and how many miles on the PT first?
Sticking or slow reacting servo's from lack of periodic fluid and filter changes causing a varnish to build up.
Old 14 Aug 2013, 05:04 pm
randyincctx's Avatar
Lightbulb Re: Transmission issue!!
I think one way you could check to see if its motor mounts vs transmission is to see what the engine is doing when it's shifted from Park to Drive,and/or reverse.....If the engine is jumping around like the one in this Youtube video.....It's probably the motor mounts;If it's not then more than likely it transmission related.
Aka:~KILLER~
Old 17 Aug 2013, 10:32 pm
67k on it now, and the motor mounts looks good..
Old 18 Aug 2013, 08:55 am
Need to look very close as sometimes the look good sitting there. With the hood up do as randy said. If it flops around , then you are good shape on the trans. If not, A fluid change and filter change may be all you need. Should do it anyway if you haven't yet.
Old 18 Aug 2013, 09:01 pm
Which fluid? The motor oil or the transmission fluid?
The last time they changed the oil they put regular oil not synthetic!! So I'll start using the synthetic..
Old 18 Aug 2013, 09:15 pm
Trans fluid. As that is what we were referring to. Far as the oil . The most important part is to change it regularly. And follow the manual an proper cool down procedures for the turbo for shut down.
Old 19 Aug 2013, 01:11 am
Gram; If you haven't already done it, change the transmission oil filter and transmission oil. Use atf + 4 fluid only.
Busted_PT likes this.
transmission issue?? mdskinner731 General PT Cruiser Discussions 8 18 Mar 2013 03:19 am
Transmission Issue Need Help !!! newpt4me Tech & Performance Forum 5 13 Aug 2011 09:49 am
Transmission Issue Dhycin Tech & Performance Forum 4 15 Jun 2010 04:23 pm
Transmission Issue? extski Tech & Performance Forum 4 05 Jul 2009 01:15 am
Transmission issue... MDCruiser Tech & Performance Forum 10 06 Mar 2006 08:14 pm
