Cooling Fan
Old 13 Aug 2013, 12:33 pm
Default Cooling Fan
I have a 2009 PT Cruiser and I'm having issues with my air conditioner. When I'm driving, my a/c runs fine. when i stop at a light, my engine shakes and the air gets warmer. I removed one of the cooling fan relays and the a/c worked fine but i go the check engine light. I replaced the relay with a new one and the problem continued. not sure what's going on. Any ideas?
Old 13 Aug 2013, 06:53 pm
randyincctx's Avatar
Lightbulb Re: Cooling Fan
Have you checked the a/c drivebelt for proper tension and/or wear?
Aka:~KILLER~
Old 14 Aug 2013, 10:05 am
Default Re: Cooling Fan
Haven't tried that yet. I will do that after work today. Thanks.
Old 05 Sep 2013, 06:36 pm
The question are the fans working properly? try reenacting the same situation in your drive way and simply mist a garden hose over the unit while stationary and the ac engaged. the water cooling effect will be duplicated to give it more radiant cooling. The issue is do you have one or two fans and are they both working. IF they are how many speeds fans are they and are they running at high enough speeds at idol. If it is pulling the motor down that much it may be caused by producing too much head pressure at idle due to not enough ram air cooling. Back to basics, check for a clean condenser and radiator area, proper fan useage and speed. If the ac works well the rest of the time could be overloading with head pressure due to not enough cooling going on
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
cooling fan PTparty Tech & Performance Forum 5 25 Oct 2011 09:40 pm
Cooling Fan bciardelli General PT Cruiser Discussions 1 02 Jun 2011 04:41 pm
Cooling fan... need help Jimmyo General PT Cruiser Discussions 4 06 Jun 2010 10:54 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
