P0442 and p0455
Old 13 Aug 2013, 01:47 pm
Default P0442 and p0455
i have 2 codes p0442 and p0455 both evap small and large leak is the evap sensor in the gas tank bad or any ideas i could use some help ijust changed my purge syneloid cause my car was running rough idle
Old 13 Aug 2013, 02:08 pm
Default Re: P0442 and p0455
Check out this video:
While you may not have a smoke machine to use like they do, you can get a good idea of where you should be looking for leaks.
The most likely cause is an improperly seated gas cap, but in the video you'll see the other areas that you should check as well.
Old 13 Aug 2013, 02:19 pm
i know its not my gas cap i replaced it so go blowcig smoke in the lines too look for a leak if no leak its the pump?
Code P0455 Khmer75 General PT Cruiser Discussions 6 11 Jul 2012 08:50 pm
Error Code P0442 and P1684????? Ramaboy Tech & Performance Forum 40 28 Jan 2010 06:36 am
P0455...large leak detected in evaporative purge system Gabriella Tech & Performance Forum 4 24 Jul 2008 08:03 pm
P0455 Code thegoldpt Tech & Performance Forum 1 11 Dec 2007 08:54 am
Error code P0442 Art Rigby Tech & Performance Forum 2 27 Apr 2007 11:41 am
