crankshaft position sensor issue!!!!!
Old 15 Aug 2013, 08:35 pm
Default crankshaft position sensor issue!!!!!
well got done rebuilding 2.4 liter dohc engine for 2001 pt. got it all back together reinstalled, when to start up the engine. cranks and builds oil pressure. no spark, no running fuel pump and injector pulse. relays and fuses check out good. the ground circuit is good for the CKP. getting a 2.6 volt from pcm, should be getting a 9 v. so the sensor can not work properly. got any ideas???
Old 15 Aug 2013, 09:29 pm
Default Re: crankshaft position sensor issue!!!!!
What about the cam sensor? Everything good there?
Old 15 Aug 2013, 09:42 pm
randyincctx's Avatar
Lightbulb Re: crankshaft position sensor issue!!!!!
Easiest thing you can check is connections....Plug & Un-plug any connectors (CKP & CPS) again,they may not have gotten a good connection the first time they were plugged in.
Aka:~KILLER~
Old 15 Aug 2013, 10:03 pm
UptownSport's Avatar
Cam timing off
Old 16 Aug 2013, 07:03 am
timing is good. ill recheck the connectors. havent check the cam senor, ill check it. but what im trying to figure out is why is the sensor getting only 2.6 volt from the pcm??????? should be getting 9 volts.
Old 16 Aug 2013, 02:53 pm
What is it at the PCM pinnout?
It's common to mix up connectors, several are the same and also very close to each other.
Interestingly, VSS (manual) uses 5v ...
Old 21 Aug 2013, 07:04 pm
pin out on pin 44 witch is the power supply for that circuit is 2.3 volts! any ideas what to do next or whats causing this?
Old 21 Aug 2013, 08:00 pm
also when I unplug all the sensors on the circuit it reads 9 volts at the pin. but plug in the cam sensor it goes back to reading 2.6 volts. unplug cam plug in the crank sensor it reads 5 volts. unplug the crank sensor and plug in vehicle speed sensor goes back 2.6 volts. but the ground for the circuit is good.
Old 21 Aug 2013, 08:48 pm
double check the wiring harness going to the alternator. could be the wires inside the harness are chafed and shorting.
UptownSport likes this.
2016 Kia Soul Plus Black
Old 24 Aug 2013, 05:22 pm
I run new power supply wires to three sensors on the circuit still having the same issues with power to sensors!!! ????? every thing has check out ok on the circuit. HELP!! this is really pissing me off!!
crankshaft position sensor ab33arch Tech & Performance Forum 23 31 Mar 2017 04:13 pm
Crankshaft Position Sensor Replaced But.. SuperTroy General PT Cruiser Discussions 10 01 Jan 2013 06:20 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
Need help in finding Crankshaft Position sensor john1561 Tech & Performance Forum 19 25 Nov 2011 01:56 pm
