Timing belt installation problems
Like Tree3Likes
  • 1 Post By Busted_PT
  • 2 Post By Busted_PT
Old 16 Aug 2013, 04:19 pm
Default Timing belt installation problems
I am trying to replace the timing belt on a 2005 pt cruiser without turbo.
Have taken it apart and cannot get the timing belt onto the tension pulley. It seems to be too short. Compared it to the original and they are the same in length and even counted the teeth. Any suggestions as to what could be the problem?
Tension pulley is a T43008
Old 16 Aug 2013, 04:41 pm
randyincctx's Avatar
Lightbulb Re: Timing belt installation problems
Are you turning the tensioner to its most rearward position before trying to put the belt on?.....If so you may be routing the belt incorrectly.
Aka:~KILLER~
Old 16 Aug 2013, 05:03 pm
To save you any future headaches;I thought you might want to see this post.
Originally Posted by Busted_PT View Post
For more info look here. About page 9 or 10. Busted_PT project 1
Timing Marks as they should look. I suggest to take pictures of yours before you put it back to show and verify their position if you run into problems later. Then you can refer back to these if a questions arise.
Aka:~KILLER~
Old 16 Aug 2013, 05:23 pm
Default Re: Timing belt installation problems
All timing marks are correct and belt is routed as per diagram.
Could it be a problem with the tension pulley? Nothing looks out of place.
Old 16 Aug 2013, 05:26 pm
Question Re: Timing belt installation problems
Either that,or odd-chance you ended up with the wrong belt?....It's happened before j/s.
Aka:~KILLER~
Old 16 Aug 2013, 08:14 pm
Losen the bolt on the tensioner use a wrench or ratchet an turn the cam or the crank bolt to pull the belt to the tensioner side and slide the belt over the pulley.
randyincctx likes this.
Old 16 Aug 2013, 08:17 pm
Thumbs up Re: Timing belt installation problems
Knew there was probably some secret tip!..
Aka:~KILLER~
Old 16 Aug 2013, 08:31 pm
No secret just refuse to let a peace of rubber out smart me. Other stuff maybe but not that.
zamfir2 and randyincctx like this.
Timing Belt Tensioner installation 2002 PT krod1776 Tech & Performance Forum 13 17 Dec 2013 09:27 pm
Having problems with timing belt sleepy General Turbo Discussions 20 14 May 2013 08:59 pm
timing belt installation??? mdskinner731 Tech & Performance Forum 10 17 Oct 2011 10:50 pm
Timing belt installation check from the top? worcestersauced Tech & Performance Forum 3 01 May 2011 09:33 pm
