Wont start
Old 16 Aug 2013, 06:50 pm
Post Wont start
2001 70000 miles on it Wife was driving and suddenly it stopped cold. I cranks but it wont start wondering if it a fuel problems Is their any way to check fuel pressure maybe fuel pump went bad put i hear noise when i first turn key for a few seconds.
Old 16 Aug 2013, 07:44 pm
Default Re: Wont start
Yes, you can check the fuel pressure by hooking a gauge to the Schroeder valve which I've pointed to in the picture below. The PSI should be between 53 and 63.
I'd also check the timing belt to see if it broke.
Old 16 Aug 2013, 08:56 pm
We replaced cam sensor and it is turning so i guess is still in tact we got changed 5 monthes ago we just checked spark plug and we no spark.
We have fuel pressure .
Old 17 Aug 2013, 07:38 am
Well, fuel and spark is what's needed. Coil needs to be checked since you replaced the Camshaft sensor...BUT, did you replace it with a MOPAR sensor or one from an after market parts store? We've seen many times that an after market sensor doesn't work at all or fails after a short time. They may look like the real thing but internally, they're made cheaply and don't last.
Old 17 Aug 2013, 03:34 pm
Swaps crank shaft sensor got a 0320 on code but still no start .
Dont see spark what else causes spark to miss cleared code still have P0320
code. Any other ideas what to trouble shot.
Old 17 Aug 2013, 03:47 pm
randyincctx's Avatar
Lightbulb Re: Wont start
Check the CPS(camshaft position sensor) wiring front to back,and see if there are any breaks or signs of wear......If the wiring is worn or broken even a brand new CPS may not work correctly
Aka:~KILLER~
Old 18 Aug 2013, 12:18 pm
Gona change connector and see what it dose hope it dose the trick .
Old 19 Aug 2013, 08:04 pm
Changed connector to be sure it was failing nothing took a chance and bought coil pack but nothing stii in the same dilemma.
Old 19 Jun 2014, 11:48 am
did you ever find out what was wrong with your car y it wouldnt start
pt wont start gee77060 Tech & Performance Forum 13 13 Nov 2014 09:14 am
Car wont start Lynxx007 Gulf PT Forum 3 02 Feb 2013 09:14 am
I NEED HELP! CAR WONT START! AshHow Tech & Performance Forum 6 17 Dec 2012 01:22 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
