PT 2006 overheating with smoke
  • 1 Post By CREWZIN
Old 21 Aug 2013, 12:03 am
skylight's Avatar
Administrator
Default PT 2006 overheating with smoke
yesterday on my way home, my '06 PT suddenly display and sound off overheating signal.
while searching for a suitable place to stop, white smoke starts to appear in front of my windscreen from the hood and i heard boiling sound from driver seat.
after cool down (about 20 minutes), i slowly drive back home (within 500meter) with aircon off. the temperature meter at normal.
then i tried to look around the radiator, the fan seems to be spinning at that moment.
today, i slowly drive to dealer for inspection (about 10km) with aircon off. the temperature meter at normal throughout the journey.
the dealer after doing the pressure test, said the radiator fan is not working and needs to be replaced.
it is indeed not spinning now. but yesterday the fan seems to spin fine after cooling down.
is it possible that the faulty radiator fan caused the overheating and burnt out the coolant which probably caused the white smoke?
PT Cruiser
Old 21 Aug 2013, 02:43 am
Default Re: PT 2006 overheating with smoke
Neon,
The white smoke could be either of two things: steam from a pin-hole or leak in one of the hoses or the compressor venting R134A into the atmosphere which it does if the compressor gets too hot, usually from the radiator fan not working.
The boiling sound is the coolant in the overflow bottle. It does that when air gets into the coolant system (lowering the boiling point) from being low because of a loss of coolant somewhere.
Part of the radiator fan burning out is indeed a common problem with all years of the PT. The brushes inside the motor tend to burn out causing one or both speeds of the fan to stop working.
If it was diagnosed as the fan not working properly by the dealer, replacing the fan motor will cure your overheating as long as the coolant is topped off and all the air is bled from the system.
The dealer wants an exorbitant amount of money to replace the fan and it can be replaced by you if you have the time to wait for a new fan and have some basic mechanical skills. We have the instructions in the HOW TO section of the forum but it can be a daunting procedure if you've never done anything like that before.
Not sure, in your part of the world, where you would pick up a new fan and housing which could be another problem.
skylight likes this.
Old 21 Aug 2013, 03:15 am
skylight's Avatar
Administrator
carey, thanks for the explanation.
you are right that the dealer is asking for pretty expensive rate to replace the fan.
i've never done any hands-on before, so i think i will be a sucker and let the dealer do the repair.
the dealer didnt have the fan in stock even though they are the official chrysler dealer here, so they will place order and ship from overseas. their reason being, PT is out of production so they only keep stock for very common problem parts (i guess they only keep stock for cheap and small parts).
PT Cruiser
Old 21 Aug 2013, 03:39 am
Neon,
We've heard plenty of times that owners went to the dealer and paid something like $600 for the replacement which is hard to believe. We send everyone to RockAuto Parts Catalog for parts including a new fan/housing and a Dorman fan (with lifetime guarantee) can be picked up for $100 and with our instructions here on the forum someone with basic mechanical skill can change it in about 2 hours (or less).
Anyway, another good thing to remember if when you ever overheat again is to turn on the interior heater of the car. This lets the coolant flow into the heater core using a few feet of hose and the core itself to help cool down the coolant. Not a great thing in the summer time but can help you get to a safe place to get the car fixed.
Glad you were able to get home and good luck with the fix.
Old 21 Aug 2013, 04:06 am
Good answers by Crewzin. Get a guarantee too.
Old 21 Aug 2013, 04:40 am
skylight's Avatar
Administrator
Neon,
noted
hopefully after replacing the fan, it wont eventually turn out that the overheating is caused by other factor, since the technician is quite certain that the fan is the main culprit
PT Cruiser
Old 21 Aug 2013, 06:33 am
Originally Posted by skylight View Post
noted
If it got hot enough to boil over to the overflow, it also could have overflowed the overflow tank and got on the exhaust piping and steamed. The smoke.
Old 22 Aug 2013, 01:55 am
Sky; Check the coolant level at the RADIATOR cap when the engine is cold. It should be full. Install cap - run engine till temp gage gets to ~half way - low speed fan should run [visually check]. Ride around the block and you should HEAR the high speed fan cycle on and off.
The words 'quite certain' bother me.
Overheating 2006 Jbarr Tech & Performance Forum 10 22 Feb 2013 10:30 am
200,000 Miles and now she wants to smoke? Teknoron67 General PT Cruiser Discussions 23 13 Aug 2012 04:15 pm
2006 PT overheating after radiator flush jpassons Tech & Performance Forum 10 13 Jul 2011 05:19 pm
HO LEE SMOKE! Cal Cruzer Stage Turbo Kits 18 28 May 2005 03:18 pm
