Frong wheel noise help!
Old 25 Aug 2013, 10:26 am
Send a message via Yahoo to partyd
Default Front wheel noise help!
My PT its sick again, there is a noise coming from the front when driving slow and stopping, goes away if driving over 20mph
It sounds like rubber touching every time the wheel spins
I have check everything under the vehicle, there is nothing damage nothing is touching axels cv joins they are all ok, This is a 2004 GT with 54k miles
any idea where to look for or what it can be ?
Brakes discs and pads are 7k miles old they are in good conditions
if I don't find the problem I'm going to replace the wheel bearings just because I don't see any other problem
thank you
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 25 Aug 2013, 10:32 am
Default Re: Front wheel noise help!
thank you
If you turn the wheel left or right does the pitch of the noise change? this is usual bearing behavior.
Old 25 Aug 2013, 06:43 pm
yes, when i turn right
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 25 Aug 2013, 07:50 pm
Its a wheel bearing.
Old 25 Aug 2013, 09:40 pm
Default Re: Frong wheel noise help!
Thank you, must be because I spend 2 hours under the car and did not find anything else.
going to replace it, do i buy the bearing and have someone press it in or just purchase the hub ?
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 26 Aug 2013, 08:59 am
Buy the bearing. If you pull the hub your self. should get out pretty cheap with only the pressing to shop for , far as labor goes.
front wheel noise mem111296 General PT Cruiser Discussions 2 16 Aug 2013 08:09 am
strange steering wheel noise edb General PT Cruiser Discussions 2 16 Jun 2011 08:33 pm
noise in steering wheel twotone General PT Cruiser Discussions 8 04 Jun 2011 05:52 pm
Noise from Left Wheel neps Wheels, Tires, Suspension 1 02 Aug 2004 01:00 pm
stering wheel noise turbomangt General PT Cruiser Discussions 23 10 Oct 2003 02:06 pm
