Traction control
Old 29 Aug 2013, 03:31 am
needmoretoys's Avatar
Default Traction control
I was a little curious about how the trac control works on the PT. I was looking it up and found that some people say that it will cut fuel to an injector to reduce power to the wheels to stop the spinning. I also read that it applies the abs system to the tire that is spinning. I know when I let my heavy foot have it's way the tires spin no matter what. Maybe not so much with Trac on. But it doesn't seem like it's a big difference. Could you do the 1/4 mile with the Trac on? Would it cause any problems? I can see if it cuts injector pulse it could lean a cylinder. These are just thought in my head.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 29 Aug 2013, 09:21 am
Default Re: Traction control
I am quite sure it applies brakes only, no connection to fuel injection.
I couldn't believe how noisy it is!
Old 29 Aug 2013, 10:59 am
it applies the brakes.
Now think about the force the axles take when they are under load (spinning)and then the brakes are applied
a few people have broken axles due to the tc being left on at the track
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Traction Control? RaineMan General Turbo Discussions 3 21 May 2011 01:04 am
traction control mattsptgt Tech & Performance Forum 6 11 Mar 2011 03:36 pm
ABS and Traction Control yteka99 General PT Cruiser Discussions 9 25 Dec 2009 11:16 pm
Traction control on or off? ryeguy666 General Turbo Discussions 11 01 Apr 2007 02:09 am
Traction Control peppy General Turbo Discussions 2 06 Jun 2004 06:35 pm
