Failed Inspection due to no CEL
Old 29 Aug 2013, 09:54 am
Default Failed Inspection due to no CEL
Just got the call from my wife that my 03' Cruiser failed inspection this morning due to a missing or burnt out check engine light bulb according to the fella doing the testing. I have been researching this mysterious bulb for over an hour now and can't find a thread about it or a part number to buy it. Anyone have any insight in to how to remedy this situation?
I'm at a total loss here short of pulling the entire dash apart to find the offending bulb.
Thanks,
~Tony~
2001 PT loaded to the max!
Old 29 Aug 2013, 12:01 pm
Default Re: Failed Inspection due to no CEL
chances are you're going to have to pull the cluster. i would replace all the bulbs as long as you have it out.the bulbs i replaced on mine are 74.
2016 Kia Soul Plus Black
Old 29 Aug 2013, 12:03 pm
and i believe there's a how to in the tech section on how to pull the cluster. not too difficult just time consuming.
Old 29 Aug 2013, 12:25 pm
What kills me is I just recently did the cluster bulbs. I suppose I should have done the others as well. Any idea what the bulb looks like or have a part # so I can order it? I can't seem to find it anywhere
Old 29 Aug 2013, 01:25 pm
Ray_Dockrey's Avatar
According to this that bulb is not replaceable. All the others are but that one.
Change Check Engine light
Old 29 Aug 2013, 01:28 pm
It's a soldered led on the board. Front two covers have to come off. Then 8 brass colored screws, 2 through the gauge face . Need to removed. Several clips on the side and two or three in the middle of the rear cover. Then you can see the rear of the board. Not sure how the board separates from the gauges. Fun. Might just be easer to buy one used. Get one with the milage close to correct. What you buy is what will show.
Old 29 Aug 2013, 01:39 pm
randyincctx's Avatar
Question Re: Failed Inspection due to no CEL
Here in Texas if you fail a state inspection,you can go to another inspection station,and that inspector mmay miss whatever the other one failed you on....But of course we don't require a working 'check engine' light!......
Aka:~KILLER~
Old 29 Aug 2013, 01:44 pm
That's what I was afraid of fellas. Thanks for the info. I guess I'm on the hunt for a cluster. Maybe for inspection purposes, I'll just swap it out of my other PT and then put it back afterwards. I also have an 01' that just passed last week so I know that one's working lol
Busted_PT likes this.
Old 29 Aug 2013, 02:06 pm
write down the mileage so he gets the correct number on the inspection.
it would suck if you ever went to sell it and a mileage discrepancy popped up on the vehicle history report.
i know someone who had this happen to his corvette. he took it to an emissions test and it was set to KM at the time so the mileage showed up wrong and it gave him trouble when it was time to sell it.
Old 29 Aug 2013, 03:04 pm
2step's Avatar
It doesn't sound like it would be a huge problem to change the 25 cent LED, even for someone who isn't a circuit board geek. But IF you have to take out the cluster and IF you can access the "check engine" light, I suggest you put some power (5v?) to the bulb to be certain it is a bad LED and not a problem with a wire or connection somewhere else.
did not pass inspection tbandab Wheels, Tires, Suspension 0 23 Jun 2010 01:38 am
Headlight Lens Causes Failed State Inspection Johns Steel Blue General PT Cruiser Discussions 9 24 Nov 2008 12:53 pm
So much problems before inspection Ctown General PT Cruiser Discussions 3 12 Apr 2005 07:45 pm
Emmisions inspection w/Stage 1 Gear_Head Turbo Performance 6 05 Oct 2003 04:08 am
Oil filter inspection GTSteve Tech & Performance Forum 1 02 Oct 2003 02:55 am
