Hard to press horn.
Like Tree6Likes
Old 31 Aug 2013, 08:21 am
InfernoGT's Avatar
Default Hard to press horn.
I want to know if all pt cruiser horns are hard to press or just mine. I find myself hitting it multiple times because I didn't press hard enough. Compared to my neon you really have to punch the darn thing
2006 PTGT with 5spd. ~60k miles
Old 31 Aug 2013, 09:48 am
randyincctx's Avatar
Question Re: Hard to press horn.
I can press mine by using firm thumb pressure....So,you must have an internal problem with your horn;I'm not sure if that has something to do with the clockspring,or not?
Aka:~KILLER~
Old 31 Aug 2013, 09:58 am
Default Re: Hard to press horn.
Keep punching it. It'll loosen up..
My horn is so wimpy I usually just yell "F@&$?!! GO!!"
Old 31 Aug 2013, 12:24 pm
InfernoGT's Avatar
Worth a shot I guess
Old 31 Aug 2013, 01:07 pm
Wink Re: Hard to press horn.
That doesn't work very well with the windows rolled up!
Aka:~KILLER~
Old 31 Aug 2013, 01:15 pm
ptprice's Avatar
Try tapping on the bottom of your steering wheel hard enough and your horn should work. This is usually idicative of a ground connections under the dash (heavy green wires) that are not doing the work of grounding the steering wheel. Take your under dash inspection panel out and you may find the errent ground point and you can probably tighten it up a bit. When my horn doesn't work I just bang on the bottom of the steering wheel and beep beep. It's more fun. ptprice
Old 31 Aug 2013, 01:34 pm
Cool Re: Hard to press horn.
Sounds like this is what your referring to:
Horn and Radio Screen Intermittent?
But,that would normally affect the radio also......
Aka:~KILLER~
Old 31 Aug 2013, 01:39 pm
Post Re: Hard to press horn.
Originally Posted by jensenpro View Post
i'm a mechanic in ny ,have just dealt with pt radio/horn problem ,it's nothing to do with any parts or wiring harness issues,it's a riveted connection between dash bracket and steering column support if you jump with a wire between brkt and support with key on your radio will light up,jump a 12ga stranded wire between the fwd support stud and rearward support bracket half's(stud towards rear of car is fully insulated from brkt),i,m going to try to attach pix,this will fix solve the mystery
Here's a photo summary of the ground wire issue:
chigger_ns likes this.
Aka:~KILLER~
Old 31 Aug 2013, 04:23 pm
Have to press hard on the horn to activate it (08 PT) on my PT as well...doesn't seem to be an intermittent or bad ground issue...just the nature of the beast???
Old 31 Aug 2013, 05:26 pm
Ray_Dockrey's Avatar
They are hard to press and they will stick on too. Especially on the 06 and up. The ground wire fix doesn't pertain to the 06 and up as they fixed the issue on the second generation.
I replaced my vinyl steering wheel on my 09 with a leather one with the silver spokes from a limited and I stopped having horn issues. Must be a bad design on the standard wheel.
Carl48 likes this.
Changing wheel bearings, Press required? gevans Wheels, Tires, Suspension 47 17 Jun 2011 02:28 am
HELP!!! How do you remove electrical connection from oil press. switch??? 66CUDA Tech & Performance Forum 4 15 Nov 2009 07:55 pm
pt gt almost overheat/oil press.light help mtnbktrek General Turbo Discussions 6 01 Feb 2009 09:51 pm
Latest press release on my clinics turbomangt The Detail Shop 6 10 Jan 2004 12:08 am
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
