Vent Selector Broken
Like Tree3Likes
Old 04 Sep 2013, 08:36 am
Default Vent Selector Broken
Good Morning - This morning I discovered my vent selector is broken. It will only blow air out of the dash vents and won't let me change it to defrost or the lower vents. When I try to turn it to the windshield defrost it just springs back. Is there an easy fix for this? It would be a bummer this winter to not be able to defrost the windshield! Thanks!
Old 04 Sep 2013, 09:25 am
Ray_Dockrey's Avatar
Default Re: Vent Selector Broken
It is cable driven so you can take the center apart and see if it has came unhooked or if the cable is binding somewhere.
Old 04 Sep 2013, 10:15 am
Ray - Thanks for the reply. Does the center console come apart easily? I am not a very mechanical person
Old 04 Sep 2013, 10:59 am
What year Cruiser do you have? It isn't too bad at all but but knowing the year will help us give you more info to getting apart.
Old 04 Sep 2013, 03:51 pm
On a first gen, this 'spring back' will happen if the mechanical "fresh-air" default fails.
Originally Posted by Dancr5678 View Post
...When I try to turn it to the windshield defrost it just springs back. Is there an easy fix for this? ...
On a 2005 or older, the first thing I'd do is move the right-most control to the fresh air position. If a lever on the back side is stuck, the air-flow direction dial will not rotate to defrost (mix-defrost).
Click for close picture of back side of 2004 climate control showing metal bar that should slide (L-R) with refesh-recirc air dial. This dial should move to "fresh" automatically when selecting the 'defroster-mix' and 'defroster' positions. In the defrost modes, the bar locks out the 'recirc-air' position choice. Note the bar can block a light bulb fitting. The unseen third bulb is still harder to access.
Gkon likes this.
Old 04 Sep 2013, 06:22 pm
Talking Re: Vent Selector Broken
On my 2006, that symptom occurs when the blend door control arm jumps time and binds up. Moving the rotary control to dash vents will cause the cable to bend right behind the panel. Once it is bent, it must be replaced, but the cause of the binding must be repaired. The dealer told me that after the first cable replacement and repair, the entire air box assembly behind the dash must be replaced. Very expensive.
The dealer fixed mine twice and I fixed it a couple more times. After the last time, I swore to come up with a fix that would prevent the operating arm from jumping time. Recently, It happened again. I installed a new cable and made up a 1/2" square piece of hard rock maple and bridged it across the steel frame that is in front of the operating arm. A couple of holes drilled through the frame and the maple was installed with 4-40 screws and T-nuts so it lays in front of the outside of the operating arm to prevent it from springing away from the door levers and jumping time. Poor design, since the operating arm is mounted and pivots from a screw at the bottom and all the operating pressure to move the two door levers is at the top. It doesn't take much lateral play to start the problem.
I apologize for not taking pix of the fix. It was only after I had the glove box back in and everything buttoned up did I think of sharing the fix with others.
Old 04 Sep 2013, 07:17 pm
I have the same thing happening on my 05. It turns out being the cable bends outward instead of slipping into the casing like it should. I lubed it and held the cable so it wouldn't bend... moving the selector back and forth. Once I got a lot of oil in there, I then took 3 zip ties and looped them through the hole in the arm and then around the cable in order to get rid of the free play it had with the design of the end of the arm where the cable connects. It's not a perfect fix, but it works. And better than ripping the whole dash apart to replace the cable.
Old 05 Sep 2013, 12:16 am
The 2006 is nothing like that. Yours looks a bit more complicated. It isn't necessary to rip the dash out on the '06 just to replace the cable. Just remove the center front panel, the glovebox and retractor and then the cover over the arm. Not a lot of work but working under the dash will make you feel every muscle the next day.
Old 15 Aug 2017, 09:52 am
Hi NightWing,
I own an '06 PT. I'm having major issues with the mode door selector. It's stuck in defrost setting. I've had my mechanic work on this in the past...sounds like everyone is experiencing the poor design elements of this cable attachment and routing.
Any advice on taking this thing apart and troubleshooting it? I'm pretty mechanically-inclined, though taking apart dashboard parts is at the top reach of my ability.
Thanks.
PS- If anyone has any pics out there that might help, please share. Thanks!
Old 15 Aug 2017, 12:16 pm
VsandFords's Avatar
Welcome to the forum from Texas.
FYI, you are replying to an old post.
I would recommend going to the Welcome New PT Cruiser Members and tell us about yourself and your Cruiser. After that, start a new thread in the General PT Cruiser Discussions asking about the problem you are having with your selector switch.
rckstein and chuzz like this.
Center console gear selector doesn't light up hulk2 Interior Accessories Forum 13 14 Dec 2012 11:35 pm
Broken timing belt/broken valves DreamCar Tech & Performance Forum 17 13 Mar 2012 01:35 pm
Interior dash, center console and gear selector bulbs austinherman38 General PT Cruiser Discussions 2 18 Aug 2011 05:44 pm
Defrost selector flyinurse General PT Cruiser Discussions 1 11 Nov 2010 07:02 pm
Is the center console gear selector supposed to light up? ledbird General PT Cruiser Discussions 12 12 Jan 2010 01:16 am
