Electrical problem keeps blowing 12V Power Fuse
Old 04 Sep 2013, 04:23 pm
Default Electrical problem keeps blowing 12V Power Fuse
Hello,
So I have had to replace the 12V fuse so many times, I have deemed the cigarette lighter outlet unusable. It will only give me power for about 20 minutes or so then it will blow. I have had other wierd electircal problems such as the radio, a/c, and windows went out once for a few days. Should I replace all my relays and are they expensive and readily available from auto parts stores? Is there a specific ste of relays that I should replace first? Also would putting in a larger fuse be a bad idea for my 12V outlet? Right now I have been replacing with the same wattage as what was originally installed but what if I add 10 more amps in rating to that. I have a long distance drive that I want to use a converter for.
Thank you for your time. Have a nice day.
-Rob
BLOWING FUSE 13 hillbilly678 General PT Cruiser Discussions 7 04 Jul 2012 04:45 am
fog lamp fuse blowing smilanatu Tech & Performance Forum 13 19 Jul 2009 11:07 am
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
Fuse Blowing Zoomer General PT Cruiser Discussions 2 19 Jun 2009 11:48 pm
HEATED SEATS (FUSE KEEPS BLOWING) BIGZ General PT Cruiser Discussions 9 16 Feb 2009 10:39 pm
