Number 1 not firing off coil
Old 06 Sep 2013, 09:58 am
Default Number 1 not firing off coil
Well just as the title says i have a 2001 and the number 1 off the coil is not firing. Its not showing any codes that would have anything to do with it. Can someone help me to what it can be. If it was the cam sensor would it not be 1&4?
Old 07 Sep 2013, 06:12 pm
Default Re: Number 1 not firing off coil
If you're sure its not the spark plug wire and wanna play "throw parts at it till its fixed" (like I do) replace the coil pack.
Do you have an aftermarket coil such as an MSD? I had one. It was the reason why I had misfiring and stalling problems. As soon as I replaced with an oem coil pack...BOOM! no more problems.
Old 07 Sep 2013, 06:17 pm
If your not getting the fire to the #1 plug. It's ether the coil , wire, or plug.
Old 08 Sep 2013, 08:51 pm
So, you don't have a tester???
I actually bought a half dozen of these, gave away 4 of them to friends and have kept two for myself. You actually can move it around, plug it onto the coil with the other end into the wire, and if you get a lite you'll know the coil is okay. You can go from the wire to the plug, then you'll know the wire and coil are okay.
Personally, I just swapped my older 8.5mm plug wires for 10.2mm racing wires, the engine started idling smoother than ever, but now I'm getting daily faults of P0302, misfire on cylinder 2. That being said, I'll be doing the same testing to see if it's actually misfiring or what...
On yours, it's hard to tell without actually going there and putting my hands on it to see if it's really working. Add to it, I'm not sure why but shouldn't it be throwing codes???
Old 09 Sep 2013, 09:47 am
2step's Avatar
Howdy Cleven....
You are correct in wondering about the coil. If the coil had failed, I believe two cylinders would be a problem, not just one. You can switch a couple of wires to see if the problem clears up or moves to the other cylinder. Sometimes the metal connectors inside the plug wire boots have pulled loose or were not entirely seated. Check the spark plug to be sure it's seated properly. Take it out for a visual examination. Any issues such as cracking, bad or missing tips and cross threading should be apparent.
A long while back, I had a problem where the 4th plug wire (driver's side) was looping up and touching the throttlebody and even though it was a "premium" plug wire with extra thick silicone insulation, the spark burned a tiny pinhole where the touching point was, causing the plug not to fire. The coil, plugs and wires seem simple and basic but a lot of things can and do go wrong so check everything.
Old 09 Sep 2013, 11:36 am
Don't know if this applies but I had one leg fail on a Ford six cylinder car. Thinking they make these things the same technology. What you guys think?
Old 12 Sep 2013, 09:31 am
How did you determine # 1 isn't firing if there is no code?
It should trip the check engine light and log a P0301 code.
2001 PT cruiser not firing no codes bentonggbn Tech & Performance Forum 13 19 Jul 2014 10:09 am
Not Firing Koseck Tech & Performance Forum 3 20 May 2013 02:45 am
Please help again - Sputtering and Back firing clickhere4dawn Tech & Performance Forum 10 23 Nov 2012 11:25 am
2002 PT Cruiser not firing fletch65 Tech & Performance Forum 28 20 Apr 2011 09:46 am
Miss firing code cyl 4 devil9 Tech & Performance Forum 3 04 Jun 2010 09:36 am
