starter just clicks once....
Old 10 Sep 2013, 08:54 am
Default starter just clicks once....
Gentlemen,
I have a 2002 cruiser, auto, with 85,000 miles. About 2 weeks ago when starting a little different than usual, but still started didn't think anything of it. Well last weekend, went out to dinner and all I got was ONE click at the starter, thats it. Lights, radio, everything works fine. Got it towed home and the next morning I went to change the starter, but before doing it I tried it and it started right up?? I replaced the starter anyway, took it to autozone they tested it 3 times and passed all three. The car started great for the first week then yesterday just a click again.... the starter is new, the battery is less than a year old, no codes, everything works fine, no additional aftermarket stuff added. I have read many posts where this same problem has happened but no one wrote what the final solution was. I have heard the auto shutdown relay and a park/shift relay on the tranny, but I don't just want to throw money at it (like I just did)
Please help anyone run into this before??
Hoss
Old 10 Sep 2013, 09:36 am
Default Re: starter just clicks once....
Have you tried jumping it with another battery/car?
Check the cables to the starter.
Try pushing in on the ignition cylinder when you turn the key...
Those are a few ideas -
If you have fog lights, the switch may have gone bad and drained your battery, the ignition cylinder can become flaky, and cables/connections can corrode...
Old 10 Sep 2013, 11:28 am
Make sure the battery cables are clean and tight...no corrosion.
Have the battery load tested...even though it is only a year old...not unheard of for a "new" battery to die.
Old 10 Sep 2013, 06:40 pm
randyincctx's Avatar
Lightbulb Re: starter just clicks once....
You might want to check for good contact and/or corrosion on the ground wire,terminal,and bolt for the starter,that goes on the bellhousing side.......And I'm assuming the new starter came with a new solenoid,right?
Aka:~KILLER~
Just clicks once, when trying to start.. raichean Tech & Performance Forum 7 20 Apr 2013 01:13 pm
Nozzle clicks off when fueling. mbaker115 Tech & Performance Forum 15 09 May 2012 09:07 am
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
Suspension problem, ticks and clicks geronimo Wheels, Tires, Suspension 4 28 Jul 2009 04:22 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
