Door alarm when open and key removed
Like Tree2Likes
  • 1 Post By rod9669
  • 1 Post By CREWZIN
Old 10 Sep 2013, 02:38 pm
Default Door alarm when open and key removed
After searching for door alarm and reading all the results, none seem to fit my case.
2001 PT Cruiser touring edition
problem seems to have just started (unless I'm crazy)
shut off engine > remove key > open driver door and alarm sounds along with door open light on front display panel.
As I recall it never used to do that, or did it. Seems to me I could open the driver side door and no beeping alarm maybe just the door open light.
Have I gone mad or is there a way to silent the alarm??
Old 10 Sep 2013, 02:45 pm
Default Re: Door alarm when open and key removed
Just changed the ignition switch on mine today and had this problem with the new one. The plunger was not returning under spring pressure once the key had been removed, possibly due to me creating burrs by using a flat head screwdriver to start it for the last few days.
If you bang underneath the steering column does it stop?
Your switch might be on its way out
Samills6 likes this.
Old 10 Sep 2013, 03:16 pm
Hey Mr Genius your plan worked !!
Gave a whack under steering column and alarm STOPPED
Inserted key and started engine then turned engine off and open door and the alarm sounded again. One more whack and it stopped again.
That definitely seems to be the problem.
Now is there somewhere to squirt some silicone spray or something like that to stop the problem for good???
Two months ago a pin inside my lock mechanism broke and it wouldn't allow me to turn the key. The dealer was able to drill out the broken pin and insert a new one. The alarm problem just started a few days ago so I'm not sure if the pin problem had anything to do with it.
Anyway I'm happy for your quick and GOOD advice.
Sam
Old 10 Sep 2013, 03:20 pm
BTW how do I post a Star rating for you, I'm new to this site?
Old 10 Sep 2013, 04:08 pm
You already hit the LIKE button for information given by rod. If you want to rate the whole thread (stars), look at the blue line on top of the first posting for the words "rate thread" and there's a pull down menu that gives the thread 1 to 5 starts. The rating is for the usefulness/likeability of the whole thread. The LIKE button is for the person himself.
Old 10 Sep 2013, 04:44 pm
Got it, thanks CREWZIN
Has anyone removed chrome door spears? Busted_PT General PT Cruiser Discussions 37 19 Aug 2016 10:41 pm
Car thinks door(s) are open! mikelikestobike General PT Cruiser Discussions 3 02 Oct 2012 06:09 pm
'Door open' lights breakshift Tech & Performance Forum 11 24 Apr 2012 05:23 pm
Key won't open drivers door! littleblueGT General Turbo Discussions 3 20 Aug 2007 10:32 am
PT thinks a door is open? Dave Pgh General PT Cruiser Discussions 6 13 Jul 2004 01:11 pm
