code 0016 missing when warm
Old 14 Sep 2013, 10:03 am
Default code 0016 missing when warm
I have an 05 ho turbo gt. when i bought it it had a warped head. i bought a used head (all numbers matched) and put it on. replaced cam and crank sensors, and replaced timing belt. When I start her up she runs great. until she warms up about a third of the way. at that point the check engine light comes on (code 0016)and it starts missing or backfireing when it shifts and when you tromp on the gas. I have reset the timing 4 times (went one tooth each way) and it still does it. can't figure this one out any ideas?
Old 14 Sep 2013, 10:28 am
Default Re: code 0016 missing when warm
You likely need to do a cam/crank relearn procedure. This requires the use of a DRB or Witech dealer scan tool.
Old 14 Sep 2013, 11:40 am
is that a dealer only thing? expensive?
Old 14 Sep 2013, 11:51 am
Yes, it's a dealer tool. I don't know of any 3rd party tools that can do it. Maybe the Snap-on one can.
Where are you located? I have no idea what a dealer would charge to do this, but I know a few people around the country that can do it that would be reasonably priced.
Old 14 Sep 2013, 12:59 pm
el paso tx
2001 PT Cruiser dies after warm up, restarts ten minutes later, code 0320 Craig1967 Tech & Performance Forum 3 08 Aug 2013 06:30 am
eror codes 0344 0016 0522 graydon1973 Tech & Performance Forum 6 24 Sep 2012 08:35 pm
01 2>4L rough idle when warm w/p1193 code pthead Tech & Performance Forum 4 02 Apr 2012 05:43 pm
01 2>4L rough idle when warm w/p1193 code pthead Tech & Performance Forum 0 25 Mar 2012 06:22 pm
Warm A/C TaylorMade General PT Cruiser Discussions 5 12 Jul 2004 10:25 am
