Water Pump overheated 130K Tbelt time
  • 1 Post By Busted_PT
Old 19 Sep 2013, 01:22 pm
jetmax's Avatar
Default Water Pump overheated 130K Tbelt time
Looks like Timing Belt and Water pump time.
A lot of steam and running hot so turned off. After cool down noticed it was wet behind belt and at bottom of belt guard (along with road). Strange that the radiator fluid was red. Hope I do not have a leak in the radiator that's causing transmission fluid to seap in.
I checked all fluids, topped off overflow tank and drove it home (10miles - 50mph) no issues. Got home overflow is low again.
Anyway I'll be putting it on jacks Saturday with wheel and belt guard off and starting it. I'm expecting to see fluid leaking
If so I guess I will order a WP kit from Amazon $102.84 shipped Gates TCKWP265 Engine Timing Belt Kit with Water Pump : Amazon.com : Automotive
Let me know what I need and any tips. I'm sure my other PT (110k) will need this next.
01 PT Limited Edition in Silver 174k miles
Old 19 Sep 2013, 02:33 pm
randyincctx's Avatar
Lightbulb Re: Water Pump overheated 130K Tbelt time
At 130K it is MORE than highly probable that it is the timing belt(surprised you made 130K!);Also,if your sure it's the water pump that needs replacing,then of course the timing belt is definately one of those 'while your there' kinda things(along with new thermostat,and Alt & A/C belts).....Question: Was your coolant red before before the overheat situation???.....Because Dexcool(and a few others)are supposed to be red,Mopar is red/pink'ish'(not all coolants are green or yellow).......As far as any tips,or suggestions;I didn't notice on the Gates kit that you ordered,where it lists W/P gasket,or thermostat?,and as I mentioned above Alternator & A/C belts....Maybe even new crank seal?(while your there/might as well).....And of course ptcruiserlinks forum/the internet/repair manual certainly can't hurt either!......And maybe reading this thread,in particular starting on Pg. 10(at least!): Busted_PT project 1
Aka:~KILLER~
Old 19 Sep 2013, 06:51 pm
Default Re: Water Pump overheated 130K Tbelt time
Take pictures before you take things off. Take picks of the timing marks and bolts and brackets. Even groups of bolts that go to a particular part or parts. So you know were it all goes when you go back together. Take a couple of pictures of all the timing marks when you put the knew one on. Start the pt with the motor still loose. In case you need to redo the belt. Look in the tech and performance section and use the how to threads there.
randyincctx likes this.
Old 22 Sep 2013, 12:23 pm
jetmax's Avatar
Default Radiator cracked at top
No leaks by w/p, but found a radiator leak at the seam. I'm off to Advanced to pick up one for around $90 after $40 off $100 order.
Old 22 Sep 2013, 01:35 pm
Great news. lesser of the evils. You should make a plan for the timing belt change before a tow bill makes that plan for you.
WATER PUMP DCP General PT Cruiser Discussions 5 31 Mar 2013 11:44 am
water pump dingdangdo Tech & Performance Forum 4 20 Jul 2012 05:34 pm
HELP - cam belt and water pump Jassy Tech & Performance Forum 3 21 Apr 2011 09:23 am
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
