180k should i replace the struts
Old 19 Sep 2013, 10:31 pm
Default 180k should i replace the struts
would you guys replace the struts and or springs at this mileage?? It rides fine and they are not leaking.
Old 19 Sep 2013, 10:41 pm
randyincctx's Avatar
Question Re: 180k should i replace the struts
Are you sure they've never been replaced before??
Aka:~KILLER~
Old 19 Sep 2013, 10:42 pm
PTJunkie's Avatar
Default Re: 180k should i replace the struts
At 180k I say most definitely yes.
William____
2004 Bright Silver PT Cruiser Turbo GT H.O
Old 19 Sep 2013, 10:51 pm
I bought the car with 70k,,,,they sure look OE. I used to replace shocks at around 50k but that was when they were 15 bucks. Now I read if they are not leaking they are still good. I have not priced them out but I'm guessing they are around 50 dollars each plus alignment. I don't want to spend the cash if not needed.
Old 19 Sep 2013, 11:13 pm
dom92's Avatar
Is it really that unlikely that they are original? My shocks and struts are original still and I'm at 115k miles, only thing I've done on the suspension is the control arm bushings (actually just replaced the whole control arm for those, the bushings are a huge pain to replace separately). Those are pretty much a "change them when they wear out" type thing, they don't really have a specific mileage to replace, though yeah most only last 60-70k miles. Luckily I live in a place with mostly new, smooth roads so my car has it pretty easy
EDIT: Granted, my suspension is starting to make a bit of noise when I go over dips and bumps in the road, so perhaps it's time to start looking myself.
2004 Base PT Cruiser, 5-speed, 138k miles.
Old 19 Sep 2013, 11:22 pm
Post Re: 180k should i replace the struts
They may look OE,but I have to think they may have been replaced,and have about 90K on them....The ones like this are easy to replace,or can save a little by getting the strut cartridges & springs seperate,and use your own coil spring compressor....But,on my 2003 PT (with 96K) I'm going to get these to make it as easy as pie!
Front Struts Springs Left Right Pair Set for 01 10 Chrysler PT Cruiser | eBay
Also....The PT Cruiser has got to have the EASIEST rear shocks to change,I have ever seen!
Aka:~KILLER~
Old 19 Sep 2013, 11:32 pm
I've used the quick struts before and they are nice. I guess my main question was if they are not leaking or making noise and still ride well do should I look at replaceing them even if they have 90k on them.
Old 19 Sep 2013, 11:47 pm
Lightbulb Re: 180k should i replace the struts
I guess if they're not feeling sloppy,and your still happy with them;Why change them?......But,w/90K(at least)on them,I know you would REALLY notice the improvement in the ride & handling,if they were changed......You've probably just gotten used to the way they are.
Aka:~KILLER~
Old 20 Sep 2013, 12:08 am
If it ain't broke, don't fix it
Old 20 Sep 2013, 12:11 am
dom92's Avatar
Well then I guess I never have to worry about that timing belt
Busted_PT likes this.
Should I replace the pcm? megacruiser Tech & Performance Forum 3 24 Jun 2013 03:34 am
replace alt ptsw PT Cruiser Convertible Forum 2 16 Oct 2011 05:14 pm
Need to replace the Shocks and Struts on 01 Coop Wheels, Tires, Suspension 21 18 Sep 2011 07:57 pm
Replace Struts and Shocks Art Rigby Tech & Performance Forum 1 30 Apr 2010 06:55 pm
