2007 Engine noise
Old 21 Sep 2013, 09:04 am
Default 2007 Engine noise
Hi, My 2007 Cruiser touring edition is making a grinding sound at idle, maybe a valve or pulley bearing somewhere. Car has 165k, Timing belt was probably done around 100k. Other than this, car runs fine, throws no codes, or overheats.
Video
View My Video
Thanks
Old 21 Sep 2013, 09:16 am
Default Re: 2007 Engine noise
Most likely a bearing noise, ac, tensioner, or alternator. Valves click and cclatter.
Old 21 Sep 2013, 10:48 am
UptownSport's Avatar
See lots of 2.4's in JY withe idler bearing shot.
People tell dealer to replace timing belt-
That's exactly what they do.
Old 21 Sep 2013, 10:58 am
So its something to do with the timing belt? Or is their a idler pulley on the accessory belt?
Old 21 Sep 2013, 08:02 pm
How could any of us possibly know?
They'd both make same noise and are in same location.
Old 22 Sep 2013, 07:29 pm
It seems to be what I didn't want. Sound is coming from behind the timing belt cover, maybe a pulley bearing, or water pump. The car has had a squealing noise when accelerating sometimes and I believe that is usually water pump bearings, or a belt.
Busted, thank you for your help. That at least gave me ideas of what to check for. Thanks again.
Old 25 Sep 2013, 12:01 pm
Water pump bearings are bad, which explains the occasionally squealing sound upon accelerating sometimes.
Engine swap 2001 to 2007 boerter Tech & Performance Forum 7 16 Feb 2014 11:08 am
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Noise on 2007 when accelerating from stop. Gamer92 General PT Cruiser Discussions 15 06 May 2013 12:52 pm
2007 2.4L interference engine? kaekae6 Tech & Performance Forum 21 11 Feb 2013 12:03 pm
2003 to 2007 Engine swap question luckybadazzboy Tech & Performance Forum 0 10 Sep 2010 08:47 pm
