Suspension Bushing Lubrication?
  • 1 Post By randyincctx
Old 27 Sep 2013, 11:13 pm
rckstein's Avatar
Default Suspension Bushing Lubrication?
I have an '06 Touring Edition with 96,000 miles. I could not find anything in a previous thread that answered my question, so I posted a new thread. Has anyone had any experience with lubricating the rubber suspension bushings on their PT? Don't do it? What kind of lubricant to use if one decides to do it?
A couple of years ago, all of the rubber suspension and sway bar bushings have been replaced under my extended warranty. The control arm bushings were torn and the sway bar bushings were just dry rotted and caused a lot of squeaking.
Many warnings on the net advise against using any kind of an oil or petroleum base lubricant on rubber bushings as it can degrade the rubber. I think silicone is too thin, what about a teflon based lubricant?
My local Chrysler dealership doesn't have any recommendations because there is nothing mentioned about this in their manuals. I would appreciate any insight as I would like to prolong the life of the new bushings as my extended warranty will soon expire.
Old 28 Sep 2013, 06:19 am
Default Re: Suspension Bushing Lubrication?
Maybe a product that is made for rubber, such as tir shine and such. The taflon still may have some patrolum products in it. You will have to check.
Old 28 Sep 2013, 08:22 am
When I bought a rear sway bar, it came with a small tube of lubricant for the bushings - maybe contact Eibach for a lubricant....
Old 28 Sep 2013, 01:15 pm
soonercruiser's Avatar
Cool Re: Suspension Bushing Lubrication?
Probably a Silicone spray.
Frank, aka SOONERCRUISER,
Old 28 Sep 2013, 03:36 pm
randyincctx's Avatar
Lightbulb Re: Suspension Bushing Lubrication?
Energy Suspension - Bushing Lubricant "Formula 5" Pre-Lube is a versatile, waterproof, non-melting grease. It forms a tough, durable, chemical resistant film of lubricant. Prevents metal-to-metal contact even under severe shock loads. Only a small amount is required to properly lubricate bushings and metal components and to prevent corrosion. Energy Suspension 9.11110 - Bushing Lubricant | O'Reilly Auto Parts
rcktpwrd likes this.
Aka:~KILLER~
Old 28 Sep 2013, 04:28 pm
Default Re: only here will you read this info lol
Any *Propylene glyco wiped or sprayed on rubber suspension components will not only stop the squeaks but slow down the deterioration.
There was a really good product available years ago in small quantity retail containers i.e.8oz. But the Chemical supplier that bottled this under the McKay lable decided to remove and sell minimum 1 gal case 4 wholesale only. There are many companies that buy this chemical and mix it with a thickener and offer or include in their individual parts?
*Not all anti freeze is straight PG. You can also get a food approved PG. 1,2-Propanediol works as well.
Old 29 Sep 2013, 11:27 am
UptownSport's Avatar
There isn't any rubber that needs lubrication except, possibly, sway bar bushings.
Lower Control Arm ( "LCA") bushings flex; it wold be like lubricating a torsion spring, just no need for it.
Aftermarket Urethane bushings come with lube, they work differently that OE style bushings, though.
Energy Suspension Bushing - Lower Torque Mount - Is this correct? greeley Wheels, Tires, Suspension 4 25 Sep 2013 09:52 am
energy suspension control arm bushing questions jamestown478 Tech & Performance Forum 5 04 Jul 2013 10:36 am
Bushing kit dadjmon Wheels, Tires, Suspension 7 23 Jul 2011 07:06 am
Bushing Kit from Energy Suspension chigger_ns Wheels, Tires, Suspension 9 19 Apr 2011 10:47 pm
Chassis Lubrication Points 2002ptcruiserwoody723 Tech & Performance Forum 2 29 Sep 2009 09:49 pm
