New radio now off
Old 29 Sep 2013, 05:00 am
Default New radio now off
Hi
I have just installed my new model original factory radio that I have received from the US in my 2001 PT Cruiser. The radio came on and when I switched the car off and later on again the radio would not come on. Have checked the fuses. All ok. Removed the new radio and replaced the old factory fitted tape cd radio. This one also is not working now. I am from South Africa and the radio was ordered on line. Can anyone help?
Old 29 Sep 2013, 06:37 am
Default Re: New radio now off
If the old radio isn't working now, it sounds like a power problem. Check the radio fuse again and even though it might look good, replace it and if you have a tester, check that power is coming in at the end of the line to the radio.
Old 29 Sep 2013, 08:30 am
Yep, what he said^^^^^^^!
Old 29 Sep 2013, 10:14 am
hi
Thanks for answering, no I have taken the radio fuse out and checked with a tester. It is ok. I have also checked and remove the iod fuse what some people suggested.
Old 29 Sep 2013, 11:58 am
randyincctx's Avatar
Lightbulb Re: New radio now off
Disconnect the negative battery terminal for about 5 minutes,and tap the brake pedal to remove any residual charge...Then reconnect it a see if it works after that.
Aka:~KILLER~
Old 05 Oct 2013, 04:11 am
Hi
The good news is that I checked all the wiring and voltages:,all there and the correct voltage. The bad, is that the radio still is not coming on. Decided to buy an aftermarket radio and rather remove the bugger, piece of s......... and use it for an imported doorstop. Tho only thing I have not checked or could check or activated
is the data link connector.
Thanks mates
Old 05 Oct 2013, 11:08 am
Question Re: New radio now off
Is the aftermarket radio working correctly?.....Also,someone may correct me if I'm wrong;But,I believe I saw somewhere that European (not sure about S.Africa though?) PT radios require a code for activation?(That may be the problem with a US/imported radio.)
Aka:~KILLER~
Installed New Radio, Interior Lights wont wont, Radio Doesnt receive "Constant" Power Mc5Cent Interior Accessories Forum 0 08 May 2013 06:12 pm
radio help!!!!!!!!!!!!!!! 08ptloser Sound and Security Forum 2 17 Jul 2012 09:53 pm
RADIO HELP GTcruiserkilla Interior Accessories Forum 0 18 Jul 2010 08:15 am
XM Radio Stephen R. Sound and Security Forum 1 20 Mar 2002 01:03 am
