Filling radiator tip
Old 29 Sep 2013, 11:42 am
Default Filling radiator tip
Had to refill the radiator due to a broken fitting on the heater. I found I kept spilling the antifreeze/water. To stop this I cut the top off of a 2L Coke bottle with about 2" of bottle. The screw thread portion fits snuggly in to the rad cap hole and seals, this leaves a large open reservoir to fill and let it drain in slowly.
Hope this helps others.
Tony
Old 30 Sep 2013, 01:21 am
Default Re: Filling radiator tip
Good tip. There are funnels made with radiator caps attached to help filling problem cars, like PT's, but they are pricey for occasional users. Also, if you crack the bleeder screw and attach a Mighty Vac, or similar hand held vacuum pump, while you fill also helps pull the coolant through the system.
Issues with filling up my CRD (UK) damien4884 Europe PT Forum 5 09 Mar 2013 10:12 am
Motor Mount Filling - Again asallwey Tech & Performance Forum 15 20 Feb 2013 04:23 pm
Hard Starting after filling Feul tank easydude51 Tech & Performance Forum 4 31 Jan 2011 11:23 pm
Radiator 4b316 Tech & Performance Forum 3 26 Dec 2008 05:56 pm
Filling up that tire wall tricky 4 me =[ Joeskey Wheels, Tires, Suspension 2 29 Dec 2007 01:19 pm
