trouble code
Old 20 Oct 2013, 10:00 pm
Default trouble code
after pulling the head off and resealing valves guides. I got a check engine lite. checking the codes with the key dance it just says done. Had car scanned and came up with P0016.First replaced crank sensor, then replaced cam sensor with a mopar one then went back for a mopar crank sensor still have lite. went back and check the timing belt again, then doubled checked wiring nothing I can see off hand . Is it possible to ohm out the cam and crank sensor wiring. also swapped cam target with spare one. plus swapped o2 sensor
Old 21 Oct 2013, 08:13 am
Default Re: trouble code
Did you remove the battery cable to clear the code? If not, code will stay there for several start-ups.
Old 22 Oct 2013, 09:29 pm
yes tried the battery disconnects and had reset with a scanner .Still comes back. its a 2006 and the cam wires are looking good but there no telling if something went wrong with them.
Trouble code P0203, help please! nwmike Tech & Performance Forum 8 20 Nov 2016 05:33 pm
trouble code p0601 bob1 General PT Cruiser Discussions 2 30 Mar 2010 10:02 am
Trouble light code rainier42 Tech & Performance Forum 2 22 Feb 2010 04:48 pm
trouble code Paw General Turbo Discussions 21 20 Oct 2003 11:46 pm
trouble code Punch Tech & Performance Forum 1 17 Aug 2003 06:21 pm
