Rear Door Panel Removal
Old 22 Oct 2013, 06:35 am
Default Rear Door Panel Removal
I have a small dent on the left side rear door, just at the wheel well bulge. It looks like it
can be pushed out from the inside. I have not had good luck getting door panels back
in place after I remove them. What are the gotcha's with a PT? I looked on You Tube, only
front door panels.
Old 22 Oct 2013, 05:53 pm
Default Re: Rear Door Panel Removal
I just had mine off to replace the window motor.
It is very easy just need a little brute force to pull the clips from the sheet metal, after you remove the screws from the lower portion of the panel, underneath the triangular trim piece on the upper rear (which pulls off also) and near the pull handle to open the door.
After you have the panel loose, don't yank on the panel till you reach in and undo the clip attached to the pull handle.
The tricky part is lining up the door lock button to replace the door panel, then it is a matter of lining up the pins to the sheet metal and give it a bit of a whack with the palm of your hand.
One more thing, DON'T FORGET to hook up your pull handle before you install the panel.
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 22 Oct 2013, 09:26 pm
randyincctx's Avatar
Lightbulb Re: Rear Door Panel Removal
This page might also give you an insight into the dissassembly,and reassembly is obviously the reverse. http://www.justanswer.com/chrysler/2...bo-cannot.html
Also;If you don't already have one,I recommend investing in a trim removal tool(priceless,compared to buying several replacement trim clips!),and depending on how bad your dent is,Autozone has a 'Body Tool Set' as part of their 'Loan-A-Tool' program(FREE!..Just leave deposit.),which has 2-3 different shaped hand held palm hammers to help in tight areas.OEM/Body tool set (25924) | Body Hammer | AutoZone.com
Aka:~KILLER~
Old 23 Oct 2013, 01:42 am
VegasPTGT's Avatar
Thumbs up Re: Rear Door Panel Removal
Have you tried using a plumber's helper on the dent? If you think it could be popped out by taking off the door panel, then you might be able to get it out using the plunger.
Just push it on the dent until it goes flat, then with a quick pull most dents that haven't got a crease or paint damage will pop back out.
Old car painters trick.
Old 23 Oct 2013, 03:46 am
I almost forgot......Before you do the pulling of the panel, There's a couple of more screws to remove.
The two bolts under the armrest. "they are 10 MM/Phillips head, and if you use a quarter inch drive socket, they're is plenty of room.
Door Panel removal on '06 PT CruzinGT General PT Cruiser Discussions 4 05 Aug 2011 06:06 pm
Cruiser 2010 door panel removal Moriarty Interior Accessories Forum 4 19 Jun 2011 03:31 pm
Door panel removal chuckd1991 General PT Cruiser Discussions 10 13 Jan 2011 12:45 am
Door panel removal gt_tuner Sound and Security Forum 11 20 Aug 2009 09:38 am
door panel removal jsampson Interior Accessories Forum 2 06 Jul 2009 10:23 am
