Codes P1684 & P0601
Old 24 Oct 2013, 01:47 pm
Default Codes P1684 & P0601
Hello, I just detected on my PT 2002 the codes "P1684 and P0601" after turning the ignition key three times.
Any solution to these faults?
In fact, my PT only shows "Track Off" and "ABS"
Thank you.
PENSYLVANIO
Old 24 Oct 2013, 02:09 pm
Default Re: Codes P1684 & P0601
p1684 means the battery has been disconnected, no worries there. p0601 i'm not sure of. try googling that code and see what comes up.
2016 Kia Soul Plus Black
Old 24 Oct 2013, 03:03 pm
PTpreacher's Avatar
Question Re: Codes P1684 & P0601
po601 is: Internal Control module fault condition detected. PTpreacher
Old 24 Oct 2013, 03:51 pm
Handy_Cruiser's Avatar
Thank you.
PENSYLVANIO
Yep.
I've got both of these codes too. P601 means you likely need a new ECM.
If I'm wrong, I eigerly hope someone will correct me. Please!
If not, here's the ECM I'm considering for purchase:
2001 2002 Chrysler PT Cruiser Engine Computer ECM PCM ECU Replacement | eBay
I will have to send them the part number off of my ECM, my PT's VIN and mileage. And then they are supposed to send my a pre-programed ECM ready to plug and play.
Old 25 Oct 2013, 09:38 pm
Thank you all of you for giving me an idea to fix my PT.Today, I remove the four ABS sensors, cleaned them well with alcohol, and put them again. The ABS & Track lights were off.
Once again, thank you.
PENSYLVANIO
Changing the PCM (P0601) steveclv Tech & Performance Forum 16 23 Feb 2016 07:34 am
Car just died. Codes P0320 and P1684. Help? Khmer75 General PT Cruiser Discussions 5 15 Apr 2012 10:20 pm
codes p1684 and p 0551 PTCHANDLER General PT Cruiser Discussions 3 06 Dec 2010 04:42 pm
Codes p1684 and p0340 xodeflepgirlox Tech & Performance Forum 1 08 Oct 2010 07:46 pm
UK PT Cruiser 2001 Engine Light On DTC: P0601 & P1684 Taltos Tech & Performance Forum 4 13 Jun 2009 10:42 am
