Changing Anti Freeze
Old 25 Oct 2013, 05:33 pm
Default Changing Anti Freeze
I can hear a squeal on Idle and when I start to accelerate . I was thinking it is probably the water pump , It has 50,000 on it. Should I put in some water pump lube with the anti Freeze.
Old 25 Oct 2013, 06:10 pm
Default Re: Changing Anti Freeze
My bet would be on a belt, and not water pump.
Buy some "belt dressing" and put it in on belts - if squeal goes away, then you need new belts.
Old 25 Oct 2013, 07:04 pm
Thanks I'll do that.
Old 28 Oct 2013, 03:55 pm
check out a couple of you tube videos about squealing belts. I don't think belt dressing is recomended for serpentine belts, maybe because both sides of the belt is on the pullys. also not fun to clean off after it doe,s not work and your installing the new belt.
Tags
anti freeze, water pump
anti-freeze leaking Simba522 Tech & Performance Forum 5 23 Dec 2011 07:22 pm
How did I get red oil in my anti-freeze??? rrpcguy Tech & Performance Forum 17 19 Jan 2011 09:38 pm
ANTI FREEZE??? mjb457 General PT Cruiser Discussions 2 26 Oct 2008 08:52 pm
ANTI FREEZE?? mjb457 General PT Cruiser Discussions 4 15 Nov 2007 04:11 pm
Anti-Freeze JNES PT General PT Cruiser Discussions 2 14 Dec 2003 11:46 pm
