Major Oil Leak in 2001 PT Cruiser
Old 29 Oct 2013, 06:09 pm
Default Major Oil Leak in 2001 PT Cruiser
Hi all,
Everyone on this forum has always helped me with every single issue I've ever had with this car. Now I have a major oil leak in the front middle of the car. It's making a ticking noise, which I heard was the lifters from not having enough oil. Does anyone have a simple guess where the oil might be coming from? It has 118,000 miles.
Thank you in advance!
Joanie
Old 29 Oct 2013, 07:06 pm
Default Re: Major Oil Leak in 2001 PT Cruiser
Open the hood and look where you put oil in, then look nect to it where spark plug wires go in - do you see oil pooled there? If so, you need a valve cover gasket (and plug socket gaskets) - not a very expensive problem.
Old 29 Oct 2013, 07:09 pm
No, after opening the hood, checking the oil, and listening to that ticking sound, I saw no oil except on the ground.
Old 29 Oct 2013, 07:28 pm
Possibly the oil sending unit.
Old 29 Oct 2013, 07:34 pm
Is that costly?
Old 29 Oct 2013, 07:43 pm
Part is cheap can be done from the top or bottom on yours. Shouldn't be a big deal. Some will scream Mopar part only but these are pron to be a problem. So I would get it where you get the best price.
Old 29 Oct 2013, 07:51 pm
Thank you so much for all of your time and help!
Old 29 Oct 2013, 08:07 pm
Hope we helped.
Old 01 Nov 2013, 12:23 pm
Me again I took it to two different mechanics and they had it up on the rack. They both said the engine is so saturated that they can't pinpoint the leak. Not only that, but there's power steering and transmission fluid leaks. So does this mean I should take the money and buy another car?
The one mechanic said he thinks the rack and pinion is bad as well.
Old 01 Nov 2013, 02:54 pm
If you haven't replaced the timing belt and water pump, you need to have that done as well - that alone runs around $1,000.
P0455 Major Evap Leak Major issue h_wingman Tech & Performance Forum 16 27 May 2018 12:03 pm
2001 oil leak o8bluept General PT Cruiser Discussions 26 04 Dec 2011 02:53 pm
Major coolant leak - Trying to figure out location? thec0wboy Canada PT Forum 7 24 Oct 2011 02:31 pm
Oil change trouble/major leak aix Tech & Performance Forum 5 05 Aug 2010 09:14 pm
Major detail on a well used 2001 PT SR-PT4 The Detail Shop 6 05 Dec 2006 04:37 pm
