SOMEONE PLEASE HELP !!!
Like Tree2Likes
  • 1 Post By Busa_Powered
  • 1 Post By Busted_PT
Old 30 Oct 2013, 07:04 pm
Default SOMEONE PLEASE HELP !!!
HELLO I WOULD LIKE TO SAY IT IS NICE TO SEE SUCH BEAUTIFUL CARS !!! I AM HAVING A PROBLEM WITH MY PT , WE HAD A NEW FAN CLUTCH AND DOG BONE MOUNT PUT IT AND ALL OF A SUDDEN WE ARE HAVING ELECTRICAL PROBLEMS , THE CHECK ENGINE LIGHT CAME ON AND IT HESITATED WHILE DRIVING , THEN THE OTHER PROBLEM IS THE VEHICLE WOULD GO DEAD , GAVE IT A BOOST AND IT STARTED UP ... THE CHECK ENGINE LIGHT WAS ON WHEN WE GAVE IT A BOOST TODAY & THEN WHEN IT WAS RUNNING FOR LIKE 10 MIN IT WENT OFF . I TRIED PUTTING THE KEY IN THE IGNITION AND TURNING IT 3 TIMES FAST TO SEE IF I COULD PULL SOME ERROR CODES AND NOTHING... I DID HAVE IT PUT ON A COMP AND THE CODE FIRST CAME UP AS A TCM P0700 & A TRANS SENSOR
BUT WHEN WE TOOK IT TO THE DEALER IT ALSO SAID IT NEEDED A SPEED CONTROL SENSOR SO WE FIXED THAT ALSO DID A TOTAL TRANI FLUSH WITH ALL NEW FILTERS ........ALSO THE DEALER SAID THE TRANI FLUID TEMP IS RUNNING HOT, SOMEONE PLEASE HELP THEY CHECKED THE STARTER , BATTERY, AND ANYTHING ELSE THEY COULD THINK OF...CAN IT BE A SHORT IN THE SYSTEM ?
Share
Old 31 Oct 2013, 01:17 am
Default Re: SOMEONE PLEASE HELP !!!
I think there is a short in your CAPS button
VNT likes this.
Old 31 Oct 2013, 07:17 am
VNT's Avatar
VNT VNT is offline
Calm down, go have a beer.
I would bring it back to the dealer and ask some questions since they have worked on it.
These dont have mechanical fans, just electric fans.
sounds like you had an issue with the input or output speed sensor and they serivced the trans fluid.
How old is the battery?
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 31 Oct 2013, 07:27 am
I just love it when some one answers a question that they have no clue what to give for advice. But have a clever remark to belittle a new person who don't yet know that all caps is considered yelling. I would start buy cleaning all the grounds. The battery ends, two grounds on the inner finder behind air filter, and the ground under the battery that bolts to the transmission. All easy to get to with the battery out. Pull the #8 fuse for the fog lamps. to see if the going dead issues is that. Get you battery load tested to see if it has a bad cell. Somewere to start any way. Welcom to the forum. This should have been our first sentance.
Busa_Powered likes this.
