Fog Lamp doesn't work....
Old 04 Nov 2013, 11:49 am
Default Fog Lamp doesn't work....
The car is an 2.0 Ltr. European LHD with manual gearshift...
Switch is fine.
Fuse is fine.
I checked the fog lamp:
No voltage at both fog lamps.
Both leads of the fog lamp wire are connected to gound!!(??)
What happened here and where is a splice, connector or whatever that could caused that??
Tanks for Help in advance...
sommerregen
Old 04 Nov 2013, 12:10 pm
Handy_Cruiser's Avatar
Default Re: Fog Lamp doesn't work....
If the European model uses the same multifunction switch as the US version, you may find this thread helpful:
The "Handy" Aluminum Can Mod To Fix Fog Lights.
Be sure to read the links in the first post that will tell you how to disassemble the MF switch.
You may only need to clean the contact points.
Old 04 Nov 2013, 01:09 pm
randyincctx's Avatar
Post Re: Fog Lamp doesn't work....
If it turns out not to be the MFS,you might have a bad F/L relay.....U.S. models,I think it's a (30amp) 5-pin/DPDT relay that goes in the upper corner by the thumb in photo.(On U.K. models it's on the opposite corner/right side)
Aka:~KILLER~
Air conditioning makes a thump when turned on and doesn't work omega4040 General PT Cruiser Discussions 8 05 Nov 2013 03:50 pm
A/C Doesn't Work when Idle - Do I need a Fan? mriggins Tech & Performance Forum 10 29 May 2013 02:24 am
2008 pt cruiser cigarette lighter/car charger doesn't work help!!! Lori Interior Accessories Forum 4 09 Dec 2012 09:41 am
air conditioner doesn't work... problem with switch kcerica Tech & Performance Forum 4 27 Jul 2011 07:22 am
fan doesn't work but doesn't overheat 4SPEED General Turbo Discussions 3 07 Nov 2009 10:20 am
