Intrument cluster comes on and then turns off
Old 05 Nov 2013, 12:28 pm
Default Intrument cluster comes on and then turns off
I have a 2003 PT base model. A couple of the lights on the instrument cluster burned out so I replaced them. Now when I start the car they are all on but, about 5 minutes later, a couple shut off. I assume that something must be overheating or something. If anyone has an idea i would appreciate the help.
Old 05 Nov 2013, 06:03 pm
rckstein's Avatar
Default Re: Intrument cluster comes on and then turns off
You might try resetting your instrument cluster. To do this, turn the key on and be sure that your odometer is displayed, not one of the trip meters, then turn the key off. Push in and hold the trip reset button and while holding in the button, then turn the key to the on position, continue to hold in the reset button. The system will go through a self-diagnostic that will test all the gauge needles and lights. This resetting may be enough to fix your issue.
See the following YouTube link for the same information:
Speedometer reset procedure - YouTube
Old 15 Nov 2013, 11:53 am
thanks for the suggestion but, unfortunately it did not work. I think that i have to either replace the cluster or just wire all the bulbs together. does anyone know if you change the instrument cluster wih a used one will the milage be correct or is that information stored in the instrument cluster.
thanks
Old 04 Dec 2013, 09:56 am
The mileage is set by the main computer. The instrument cluster read-out is just the "monitor."
Turns over but won't start fisherman Tech & Performance Forum 30 11 Nov 2016 01:38 am
Turns But Won't Fire GTCRUISER2006 Tech & Performance Forum 2 09 Jul 2012 08:10 pm
turns over, but no fire carolinagirl Tech & Performance Forum 6 04 Aug 2011 07:54 pm
Screw turns, but won't come out...? paramo Tech & Performance Forum 6 19 Apr 2011 11:54 am
My PT is OVERHEATING when the A/C turns on...not the fan!! kletson General PT Cruiser Discussions 8 10 Jul 2010 08:25 pm
