2006 Heater problems
Old 05 Nov 2013, 10:10 pm
Default 2006 Heater problems
Hi there! Just bought me a nice 2006 Cruiser, on the test drive everything seemed fine, except a little front end noise, but I got a good deal, I bought the car anyway.
On the way home the hot air from the vents suddenly turned cold (control set to max heat). I turned it off, in a couple minutes later turned it back on again: hot air, couple minutes later: cold air.
Any ideas what this could be? I have no experience with these cars at all. Just bought it today. Until now I had 70's Cadillacs...
Old 06 Nov 2013, 02:31 am
Default Re: 2006 Heater problems
Check for air in the system. --- Watch the temp gauge to see if it varies after the car is warmed up. It should stay at halfway.
Old 06 Nov 2013, 08:23 am
Yes, I have to go through the car, as I noticed it needs a couple little things, only this heater is bugging me. I noticed that if I rev it more heat comes out the vents. I hope it is not a water pump... The car does not overheat though. The gauge stays at halfway. It was sitting for a couple months not sure if it could be related...
Old 07 Nov 2013, 03:52 am
yen; I'd recheck the coolant level. Learn about the reservoir tank system and how it keeps the air out of the cooling system. Also, check for a kinked heater hose going to the heater core.
2006 problems ClownShoes Tech & Performance Forum 11 21 Sep 2013 12:59 am
heater blower problems tracker General PT Cruiser Discussions 3 22 Oct 2012 04:27 pm
o2 heater circuit problems Aristo99 General Turbo Discussions 2 04 Oct 2012 07:12 pm
............Heater Problems.............. fatboypt Tech & Performance Forum 1 16 Jan 2012 10:34 pm
2006 to 2007 Radio/Heater bezel VOETOM Classifieds: Want To Buy 0 19 Mar 2011 08:38 pm
