I have a 2003. Whenever I have the heat on, there's a high-pitched whistle that drives everyone in the car crazy. I can adjust the heat/fan controllers to minimize the whistle, but it's still there. It sounds like some kind of obstruction, but I've had a new heater core put in and work done on it to look for the source of the noise, but there doesn't seem to be any reason for it. I've also noticed that when I have the fan control on high, the heat control knob slams to max - as if maybe something isn't connected. Maybe you're just not supposed to have the fan on high with the heat on, but still... Is mine the only one that does this? Also the air flow isn't as strong when it's on heat compared to vent. I imagine that may be normal, but I've never noticed a significant drop in airflow with other cars I've had. Any ideas?
Sounds like you might have an obstruction in the air flow channeling which might also be the whistling noise....and NO, it's not normal and the flow for the heat should be just as much as the cold or vent.
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
Maybe leaves of something...ESPECIALLY if you don't have a cabin air filter installed.
I just purchased a 2005, and when I took off the plastic cowls near the wipers to access the windshield wash reservoir and install a cabin air filter there; it was full of leaves. Luckily, nothing in the ducts!
Frank, aka SOONERCRUISER, 2011 GWE Dodge Challenger SRT8 as Show Car 2003 PT Cruiser GT Panel Van Conversion as new day driver. Have now owned 6 PT Cruisers = Me PT Crazy! |
Cindy; it could be a vacuum leak in a hose or a vacuum motor diaphram. Or a dry fan motor bearing, which would change in pitch with the fan motor speed.
Tags |
air flow, heater, whistle |
Thread Tools | |
Display Modes | |
No heat at all.....06 PT | aluisi | Tech & Performance Forum | 4 | 18 Feb 2013 01:37 am |
No Heat | dsouder | General PT Cruiser Discussions | 10 | 03 Nov 2011 10:42 am |
Over Heat ? | tbcrusier | Tech & Performance Forum | 34 | 29 Jun 2011 07:08 pm |
Over heat, need some help | hulk2 | Tech & Performance Forum | 29 | 31 Dec 2009 06:29 pm |
