Starting problem
Old 14 Nov 2013, 07:11 pm
Default Starting problem
My PT wouldn't start and it appeared to be the starter. I replaced it but now I am still having a problem. When you turn the key it doesn't always start so I need to find the "sweet spot" to start it.
Is this the ignition switch? If this is changed would I also need new keys?
Thanks in advance.
Old 14 Nov 2013, 07:40 pm
randyincctx's Avatar
Lightbulb Re: Starting problem
Thanks in advance.
That sure sounds like the 'Ignition Switch' and/or 'Actuator Pin' is your problem......The 'Ignition Cylinder' is what the key fits into,and if replacing it you don't need to replace your keys,if you change the new tumblers to match.
Aka:~KILLER~
Old 14 Nov 2013, 09:23 pm
Default Re: Starting problem
But that probably not the part you need. You should look at the part that the wires plug into. Had to replace this on one of mine.
starting problem skinnyp Tech & Performance Forum 10 09 Apr 2016 04:46 pm
06 starting problem rhythmbone Tech & Performance Forum 8 23 Jul 2013 05:54 am
starting problem cookie General PT Cruiser Discussions 4 17 Jun 2009 07:38 am
Starting problem Elrodion Tech & Performance Forum 0 18 May 2009 07:49 am
starting up problem packrat007 Tech & Performance Forum 11 15 Aug 2008 04:38 am
