Lock/ Unlock verification
Old 17 Nov 2013, 06:11 pm
Default Lock/ Unlock verification
When I purchased my PT, the marker lights would illuminate when the vehicle was locked and unlocked with the remote.
It quit doing it some time ago. I did the computer reset today with no avail.
Just wondered if anyone out there in PT-ville has experienced this small but annoying problem, and what did they do to remedy it. Thanks
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 17 Nov 2013, 08:23 pm
Default Re: Lock/ Unlock verification
Does the horn still beep when you lock or unlock the car?
Old 17 Nov 2013, 08:37 pm
As long as all of your door locks and light bulbs otherwise function normally, your problem is most likely to be the RKE module and the fix would be replacement.
According to the Mitchel Repair guide for 2002, RKE pins #1 & 2 power the light flashes when the remote keyless entry is used. This is true whether an alarm is present or not.
There is no common point between the two pin circuits and no fuses. You might check the RKE module connector for signs of damage.
Pin #1, violet/white wire, is spliced (S225) to light system (L4) somewhere near ignition switch connector and powers the headlight circuit.
Pin #2, black/yellow wire, is spliced (S233) to light system (L7) behind the dash center and powers the front and rear corner parking lights.
Pin #18, black/red wire powers the horn circuit.
Last edited by sanatanadharma; 17 Nov 2013 at 08:40 pm. Reason: added more information
Old 17 Nov 2013, 10:34 pm
Thanks for the info. The horn will double beep when I unlock it after locking it manually.
I never tried setting the the beep when lock function (factory setup).
I'll check the wiring by the RKE. I had it out a while ago when I had the famous no lock/ no headlight saga. The RKE was fine, turns out the main feed behind the fuse block was burnt (another common problem).
I'm not sure if the marker light flash quit then, never really noticed.
Who knows, maybe the plug is not thoroughly plugged in.
Thanks again, Gregg
Old 18 Nov 2013, 04:56 pm
I just checked up on the wiring in my service manual, and low and behold the number 2 pin from the RKE goes right to the infamous Multi-function switch.
So it looks like I will be removing the MFS (I love that acronym) AGAIN, to check those connections.
If memory serves me, I recall seeing some slightly burnt connections on the plug.
Hopefully that is the culprit, and it will just involve doing some cleaning, and tightening.
Old 19 Nov 2013, 09:28 am
2step's Avatar
If I remember correctly, the lights blinking when you lock can be set to not blink at all. It's possible that the setting has been changed inadvertently for some reason. The procedure to set it up however you wish is in the owner's manual.
Old 19 Nov 2013, 10:41 am
Insert the key and turn to on. Press and hold unlock button on transmitter for 4 to 10 sec. Continue to hold and press the lock button. Then release both. A chime will sound when complete.
Old 19 Nov 2013, 04:21 pm
Just got back in from doing this, (and I think because I have an aftermarket along with the factory setup), it just set off the panic .
The panic went off at about 2 or 3 seconds of holding the unlock. I still tried continuing with the hitting the lock at the same time, but no luck.
I did it twice, just to make sure (I'm sure the neighbors loved me).
I'm going to check my connections (after I do leaves GRRR!!). and see if any of them are burnt, or corroded.
Old 19 Nov 2013, 09:32 pm
Where can someone get an RKE module, other than the dealer and what's the normal price for a new one, or even used. thanks
Old 20 Nov 2013, 02:37 pm
pt cruiser keyless module | eBay
Auto lock/unlock issue with my car - looking for the locksmith lmoaceySus General PT Cruiser Discussions 4 11 Dec 2014 12:11 pm
Verification, please PT_Preacher Tech & Performance Forum 3 15 Aug 2012 03:37 am
Electronic lock/unlock not working chitownbabs Sound and Security Forum 5 30 Mar 2012 10:21 pm
Doors lock & unlock for no reason molnar441 General PT Cruiser Discussions 3 01 Oct 2008 02:12 pm
Doors lock & unlock for no reason molnar441 Tech & Performance Forum 2 20 Aug 2008 03:18 pm
