Well, THAT didn't take long...
Like Tree2Likes
Old 21 Nov 2013, 06:06 pm
Unhappy Well, THAT didn't take long...
I've had the PT for just over a month. Today, on my way home from work, I notice the engine warning light is on.
*sigh*
I see the owner's manual says to have it serviced if "...the light stays on through several of your typical driving cycles." So, I'm trying not to let it get me down.
Old 21 Nov 2013, 06:11 pm
Default Re: Well, THAT didn't take long...
NO, NO, NO.
Follow the steps I've outlined in this link and get the fault code yourself. Then come back here and let us know what you found out. We can walk you through almost any fault you come up with.
How to retrieve fault codes.
Old 21 Nov 2013, 06:17 pm
Originally Posted by CREWZIN View Post
NO, NO, NO.
Yes yes yes, what CREWZIN said.
Old 21 Nov 2013, 06:25 pm
There are several places in your home town in IL that you can get a free diagnostic scan and DTC reset.
IMO you should get this done with a proper Diagnostic scan tool. Make sure to write down all the DTC's that may come up before they are cleared.
Have the any codes cleared and recheck again after you cycle the engine at least one time. Many codes could be because of anomalies and may have correct themselves. So by clearing them and rechecking you save your self looking in area's that were not an issue.
I personally do not care for the self key check for DTCs as they are not always accurate.
Old 21 Nov 2013, 06:37 pm
rckstein's Avatar
*sigh*
Yeah, don't give up so easliy! I've had the "check engine" light come on for something as silly as the gas cap. Several years ago I had replaced the stock cap with an aftermarket locking cap. The vehicle was fine for quite some time then the "check engine" light started coming on. Then I read somewhere where PT's don't like aftermarket gas caps so I then replaced it with a Chrysler locking cap. All has been fine since then.
You'll learn to love your PT!
Old 21 Nov 2013, 07:01 pm
Thumbs up Re: Well, THAT didn't take long...
OK OK OK
Thanks for the tip! The code is P0551. After it showed that code, it then stated it was donE, so at least it doesn't appear that there are multiple things wrong.
A quick search of this site suggests that P0551 is a power steering pressure sensor switch; is that correct? If so, what remedy is suggested for a rather mechanically-impaired PT owner?
Old 21 Nov 2013, 07:13 pm
OK OK OK
Check the fluid level and get the code cleared. wait till to see if it happens again.
Old 21 Nov 2013, 07:34 pm
Yup.
What year is your PT? All but the earliest ones use ATF+4 in power steering.
Old 21 Nov 2013, 07:41 pm
If or when you want to do something about it after the code comes back and you want to do it yourself, we can try to help.
Old 21 Nov 2013, 07:56 pm
Question Re: Well, THAT didn't take long...
Originally Posted by quicksilverdon View Post
Yup.
Don, it's a 2005 GT.
Crewzin, assuming the fluid isn't low and that the light doesn't go out on its own, would it be a reasonable first troubleshooting step to unplug the switch, ensure that the contacts are clean, reattach switch, and see if the light goes out?
Failed Motor Mount-That didn't last long royleroyleroy General PT Cruiser Discussions 8 20 Jul 2012 02:25 pm
Didn't know this.... turbomangt Stage Turbo Kits 5 19 Jan 2007 12:07 pm
Why Oh Why didn't I buy it? jmack General PT Cruiser Discussions 3 02 Sep 2004 11:01 am
It's a long, long drive to Germany... Ed Lim Exterior Accessories Forum 0 05 Jun 2003 03:33 am
